K181 headgasket questions.
6 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted September 27, 2016 - 06:31 PM
So, the head gasket in my JD200 went last week, hoping to get into this soon, already got the new gasket, my question is what should I be on the look out for while I have the head off, I am comfortable with the head gasket part.
Also, a little background on this, this tractor had a bit of a hiss for years so I think the gasket may have been on its way out for a while, I think the final straw was when I added Lucas Oil when I changed the oil(doesn't use oil anymore:)), I think this boosted compression enough to finally do the gasket in.
  • backwoods said thank you
#2 jabelman OFFLINE
jabelman
  • 2,225 Thanks
  • 1,594 posts
Posted September 27, 2016 - 06:54 PM
I usually would decarbon everything, check the cylinder for wear, check the valves for seating, after I put the head back on I run it for a few minutes and then tighten the bolts again to seat
  • backwoods, HANKG and adamjd200 have said thanks
#3 EricFromPa ONLINE
EricFromPa
  • 3,651 Thanks
  • 3,111 posts
Posted September 27, 2016 - 09:43 PM
Check your Valve guides.Especially your exhaust valve guide.Grab the valves with your fingers when they are up the whole way and try to wiggle it.If it moves much I would replace them.It's very common for the valve guides to wear on the K161-K181.Makes them smoke a good bit.I'm replacing a couple sets as soon as the valve guides that I ordered show up.1 set in my spare 181 block and 1 set in my cub 70 that has a 181 in it.
Here's where I ordered mine.$20.50 a set shipped
http://www.ebay.com/...984.m1423.l2649
#4 boyscout862 ONLINE
  • 12,839 Thanks
  • 9,164 posts
Posted September 27, 2016 - 09:53 PM
You may need to plane the head because a long time leak can eat into the head. I've done it with a 10" file and then a surface plate and very fine sand paper. It took a couple of hours. You can download the Kohler Manual from our Manuals Section. Good Luck, Rick
#5 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted September 27, 2016 - 10:11 PM
I have seen many Kohler heads in need of a touch-up, so Rick gives good advice.
However, a 6" belt sander accomplishes the same task in seconds.
A piece of plate glass or a kitchen counter can often be used as a flat surface.
  • HANKG said thank you
#6 Trav1s OFFLINE
Trav1s
  • 3,306 Thanks
  • 4,359 posts
Posted September 28, 2016 - 07:23 AM
I lap the head using this process:
Definitely want to true it it.  I went through a similar problem on the '66 110 owned - the gasket let go right next to the valves.
#7 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted September 28, 2016 - 11:28 AM
This was my planned method, I don't have that big of a sander, and I don't have a steady enough hand with a file.
