Tire mounting ?
14 replies to this topic
#1 HANKG ONLINE
HANKG
  • 5,979 Thanks
  • 3,290 posts
Posted September 27, 2016 - 11:12 AM
I have a pair of 23-10.50-12 AG tires and 10.50-12 rims to put them on. The rim seems to small inside the tire how do you get the bead to seat ? These are stiff tires, is there a tool to squeeze the center of the tire so the side walls push out enough for them to seat ? take them to a truck tire center ? HELP.
  • chieffan said thank you
#2 SimplyRad OFFLINE
SimplyRad
  • 860 Thanks
  • 685 posts
Posted September 27, 2016 - 11:18 AM
I broke the bead on the front tire my ZT1500 and the bead would not seal with a tight fit. I used a tie down strap and cinched it up until the bead would seal. Was a real PIA.
  • KennyP, boyscout862, HANKG and 2 others have said thanks
#3 SupplySergeant OFFLINE
SupplySergeant
    Eggman's Dad
  • 1,612 Thanks
  • 914 posts
Posted September 27, 2016 - 11:25 AM
I plan to use a tube, myself. Seems like these things are pretty tough to seat, but I've seen folks use the ratchet strap around the outside, and even starting fluid sprayed in, then lit to blast it on the bead! Good luck!
  • limebuzz, boyscout862, HANKG and 1 other said thanks
#4 olds45512 OFFLINE
olds45512
  • 1,238 Thanks
  • 626 posts
Posted September 27, 2016 - 11:46 AM
The rim is to wide, a 10.50 tire is usually mounted on an 8.50 wheel.
  • Gtractor, boyscout862, HANKG and 3 others have said thanks
#5 HANKG ONLINE
HANKG
  • 5,979 Thanks
  • 3,290 posts
Posted September 27, 2016 - 12:12 PM
You are exactly correct they sent the wrong size rims and I did not know they wouldn't fit.
  • SupplySergeant and chieffan have said thanks
#6 olds45512 OFFLINE
olds45512
  • 1,238 Thanks
  • 626 posts
Posted September 27, 2016 - 12:55 PM
glad I could help.
#7 SupplySergeant OFFLINE
SupplySergeant
    Eggman's Dad
  • 1,612 Thanks
  • 914 posts
Posted September 27, 2016 - 01:09 PM
Learned something useful here, thanks!
#8 Gtractor OFFLINE
Gtractor
    The Tractor Hoarder
  • 8,630 Thanks
  • 4,700 posts
Posted September 27, 2016 - 02:45 PM
I wouldn't say they "wouldn't fit".  It'll work but as you know its not gonna be easy.  Tube might be your best bet at this point.
#9 SupplySergeant OFFLINE
SupplySergeant
    Eggman's Dad
  • 1,612 Thanks
  • 914 posts
Posted September 27, 2016 - 03:02 PM
What size tire would normally be mounted on a 10.5 rim? 26-12.5-12?
#10 dropped82 ONLINE
dropped82
    Nut Case
  • 2,158 Thanks
  • 1,647 posts
Posted September 27, 2016 - 03:16 PM
26x12x12
  • SupplySergeant said thank you
#11 KC9KAS OFFLINE
KC9KAS
  • 5,202 Thanks
  • 4,585 posts
Posted September 27, 2016 - 04:44 PM
Someone is looking for those 10.5" wide wheels!
#12 KennyP OFFLINE
  • 35,073 Thanks
  • 44,094 posts
Posted September 27, 2016 - 04:55 PM
A ratchet strap and sunshine could be your friend!
  • HANKG said thank you
#13 chieffan OFFLINE
  • 8,799 Thanks
  • 6,034 posts
Posted September 27, 2016 - 05:22 PM
Lot of times when I get a bead leak which is common on old tires, I remove the valve core, roll the bead down away from the rim enough to work some slime in with an acid brush.  Did that again this morning on a front tire on a QT.  One side was leaking 1/2 way around.  Give it the slime treatment, 15 lbs of air and let it sit.  Had 14 lbs this evening so tomorrow it goes back down to 11 or 12.
#14 olds45512 OFFLINE
olds45512
  • 1,238 Thanks
  • 626 posts
Posted September 27, 2016 - 05:23 PM
If you've even looked at a tire while it's off the rim you will see that the sidewalls naturally angle in, if you put a 10.50 tire on a 10.50 rim it will force the sidewalls to be straight which could easily lead to the tire popping off the bead if you run them low on air or hit a big enough bump.
#15 HDWildBill OFFLINE
  • 8,972 Thanks
Posted September 27, 2016 - 06:37 PM
The trick to using the rachet strap is you only tighten it just enough for the bead to be touching the shoulder of the rim.  Take the valve core out and you need a large volume of air to get the beads to seat. Hit it hard and fast with the air and that usually works on.
I had a rim go bad on my MC so today I took a new to me rim and mounted the tire from the bad rim.  Went on like a greased pig but when I put it on the other rim it fought me tooth and nail.  Tires can be funny beast's.
  • HANKG, Sawdust, SupplySergeant and 1 other said thanks
