ASECC Website Info?
7 replies to this topic
#1 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 703 Thanks
  • 591 posts
Posted September 27, 2016 - 11:04 AM
For those of you that have ever used this website, there is a lot of valuable information on this site regarding old Briggs engines. Does anyone know what happened to this site?? I should have saved every PDF on there a long time ago, but I didn't. I needed to reference the sears model 500 5 and 6 digit number PDF's but they are gone. If anyone ever saved those and could send them to me I'd greatly appreciate it!
Mike
#2 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted September 27, 2016 - 01:23 PM
Mike, Here is an archive of the site in the wayback machine.  https://web.archive..../www.asecc.com/
  • Gtractor, MH81, Alc and 3 others have said thanks
#3 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,311 Thanks
  • 4,948 posts
Posted September 27, 2016 - 02:41 PM
Thanks Doug!
Now!  Who has the archive for Sonnys Bolens?
  • GTpicker01 said thank you
#4 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 703 Thanks
  • 591 posts
Posted September 27, 2016 - 03:25 PM
Thanks that has some Briggs data I wanted, but unfortunately the when you click on the PDF for the sears 500 numbers nothing comes up.
#5 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted September 27, 2016 - 05:05 PM
Thanks Doug!
Kris, if you have the original URL you can search for ir at that site from the homepage. Maybe you will get lucky.
There is another site that has Bob Learned's info posted but I don't think he had the Sears numbers. I'll have to find it and see.
  • Gtractor said thank you
#6 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted September 27, 2016 - 05:15 PM
Here is the 6 digit chart but I haven't found the 5 digit one yet. If you look at the top there are different dates when it took copies of the website. This was in Nov/14
WELL......it looked good until I posted it. Then the site condensed it.
Type No. Model Type No. Model Type No. Model Type No. Model Type No. Model Type No. Model 105010 to 105499   6 203510 to 203799   23FB 500000 to 500499 140300 140400 706510 to 706799   19FB 906010 to 906499   8B 949500 to 949999   61200 105510 to 105799   6FB 203810 to 203974   23R6 500510 to 500999 141300 706810 to 706999   19R6 906510 to 906799   8B-FB 950000 to 950499   60900 105810 to 105999   6R6 203975 to 203999 23R6D 501000 to 501499 140700 707000 to 707999   23C 906810 to 906999   8B-R6 950500 to 950999   61900 106010 to 106499   6 204000 to 204099   U 501501 to 501999 141700 801000 to 801499   9* 907010 to 907099   6B-H 951000 to 951499   80200 106510 to 106799   6FB 205000 to 205999 N-NP- NR6 502000 to 502499 142300 142400 801511 to 801599   9FB* 907100 to 907499   60700 951500 to 951999   81200 106810 to 106999   6R6 206000 to 206083   IBP 502510 to 502999 143300 801810 to 801899   9R6* 907510 to 907999   61700 952000 to 952499   60200 107010 to 107499   8 206099 to 206999   I 503000 to 503499 142700 802000 to 802499   14* 908010 to 908499   80100 952500 to 952999   61200 107510 to 107799   8FB 207000 to 207999   I 503510 to 503999 143700 802500 to 802799   14FB* 908510 to 908999   81100 953000 to 953499   80300 107810 to 107999   8R6 208000 to 208999   A 504000 to 504499 140200 802812 to 802999   14R6* 909010 to 909499   80500 953500 to 953999 81300 81400 108010 to 109499   8 209300 to 209320   8H 504500 to 504999 141200 803000 to 803299   23* 909510 to 909999   81500     108510 to 108799   8FB 209321 to 209499   8AH 505500 to 505999 141200 803312 to 803499   23B* 940010 to 940499   60100     108810 to 108999   8R6 209500 to 209699 8H 700010 to 700499   5S 803500 to 803799   23FB* 940510 to 940999   61100     109310 to 109316   6H 209700 to 209799 8AH 700500 to 700599   5SFB 804000 to 804999   6* 941010 to 941499   60500     109321 to 109399   6AH 300000 to 300999   B 701010 to 701499   6S 805000 to 805199   8* 941510 to 941999   61500     109400 to 109599   6H 301000 to 301999   WI 701500 to 701599   6SFB 805211 to 805799   8FB* 942010 to 942499   60300     109600 to 109699   6AHS 302000 to 302999   K 701800 to 701899   6SR6 900010 to 900499   6B-HS 942510 to 942999   61300     109700 to 109749   6AH 303000 to 303999   I 701900 to 701999 6SR4D 900510 to 900999   6B-H 943010 to 943499   80300     201010 to 201299   9 304000 to 304499   Z 702000 to 702499   8 901010 to 901999   6B-S 943510 to 943999   81300     201310 to 201499   9B 304500 to 304999   ZZ 702500 to 702799   8FB 902010 to 902499   6B 944010 to 944499   80700     201510 to 201799   9FB 305000 to 305999   NS 702810 to 702999   8R6 902510 to 902799   6B-FB 944510 to 944999   81700     201810 to 201974   9R6 306000 to 306999   N 703010 to 703299   23A 902810 to 902999   6B-R6 945011 to 945499   80900     201975 to 201999   9R6D 307000 to 307999   N 703310 to 703499 23A-F 903010 to 903499   6B 945511 to 945999   81900     202010 to 202299   14 308000 to 308999   ZZ 703510 to 703999 23A-FB 903510 to 903799   6B-FB 946011 to 946499   84500     202310 to 202499   14B 309000 to 309110   6HS 703810 to 703999 23A-R6 903810 to 903999   6B-R6 946500 to 946999   85500     202510 to 202799   14FB 309210 to 309214   6HSF 704500 to 704599   8H 904010 to 904799   8B-H 947011 to 947499   80800     202810 to 202974   14R6 309500 to 309699   6H 704700 to 704799   8HF 904810 to 904999 8B-HA 947500 to 947999   85500     202975 to 202999   14R6D 309700 to 309999   6HF 705000 to 705100   5 905010 to 905499   8B 948000 to 948499   80200     203010 to 203299   23 400000 to 400499 100900 706010 to 706299   19 905510 to 905799   8B-FB 948500 to 948999   81200     203310 to 203499   23B 401000 to 401499 100200 706310 to 706499   19B 905810 to 905999   8B-R6 949000 to 949499   60200
#7 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 703 Thanks
  • 591 posts
Posted September 28, 2016 - 07:25 AM
Found the 5 digit list in a 2011 capture. Thank you very much for they help!
#8 drbish ONLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted September 28, 2016 - 04:26 PM
Here is a list.
http://gardentractor...by-type-number/
