Plow questions...
3 replies to this topic
#1 Greasy6020 OFFLINE
Greasy6020
  • 1,677 Thanks
  • 1,521 posts
Posted September 27, 2016 - 07:30 AM
Watching a pa plow day video, looks like some people are not running coulters on their plow...
Anyone have an idea why?
I have a plow, I accidentally busted the coulter off trying to free it up... Not sure the coulter is necessary as I've seen big plows without coulters.
#2 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted September 27, 2016 - 07:41 AM
Coulters are not always needed.  It depends a lot of the plowing conditions.  If the soil is soft, you probably don't need it.  Sometimes they just collect debris between the coulter and the plow to where you have to stop and pull it back out.  This especially happens when plowing in corn stubble.  Been there, done that more than I care to admit.  I would think that the best and possibly only times a coulter would be useful is in hard dry ground or when plowing virgin ground.
  • boyscout862, Sawdust, propane1 and 2 others have said thanks
#3 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted September 27, 2016 - 09:30 AM
Up at PAPD, the ground is turned every year.   No sod to cut through, which is what the coulter is really for.
The soil up there is pretty loamy/soft, and cuts like a hot knife through butter.  No need for it.  You'll actually do WORSE with the coulter up there.
Edited by Dane in PA, September 27, 2016 - 12:18 PM.
  • boyscout862 and Greasy6020 have said thanks
#4 olds45512 OFFLINE
olds45512
  • 1,502 Thanks
  • 739 posts
Posted September 27, 2016 - 11:51 AM
PAPD is easy plowing, I've plowed fresh ground without a coulter and did ok but it was a bit of a struggle.
  • boyscout862, Dane in PA and Greasy6020 have said thanks
