Rotten muffler = stack plan B
3 replies to this topic
#1 Alberta Bolens OFFLINE
Alberta Bolens
  • 749 Thanks
  • 343 posts
Posted September 26, 2016 - 10:37 PM
My 1st attempt at putting a stack on my 455 was not all that sucsessfull.   My welding was far from good to many bends and vibration.post-49650-0-10111200-1454308883_thumb.jpost-49650-0-46071000-1454308885_thumb.j
So I came up with plan B.  As the hood has a chunk out of the corner and is not in the best of shape.  I cut a hole in the hood directly above the manifold and run the stack throught hte hood.  Painted it flat black with high temp paint.
  • Alc, old coot and MolonLabe have said thanks
#2 zippy1 OFFLINE
zippy1
  • 636 Thanks
  • 388 posts
Posted September 26, 2016 - 11:18 PM
Okay, cool.
But how do you open the hood?
  • fonz3482, Bmerf, KC9KAS and 3 others have said thanks
#3 Cvans ONLINE
  • 6,276 Thanks
  • 5,984 posts
Posted September 26, 2016 - 11:55 PM
Sure looks a lot better. On  mine I have the muffler pipe sized so it's a snug fit onto the manifold. On the Fordson Dexta it's a slip fit into  the inside of the manifold which is slightly tapered.
#4 Alberta Bolens OFFLINE
Alberta Bolens
  • 749 Thanks
  • 343 posts
Posted September 27, 2016 - 08:18 PM
Okay, cool.
I cut the flange off of the original muffler and welded a pipe onto it about 5 inch long just about flush with the hood.  The muffler fits inside of it snuggly.  I just pull the muffler off and open hood as normal.   It does leak a little when 1st start up but as it warms up it tighens up.  I make sure to try and remember if I have to open the hood I do it before I run the tractor.  I have used it mowing etc for 2 or 4 hours with no issue yet.
Edited by Alberta Bolens, September 27, 2016 - 08:20 PM.
  • zippy1 said thank you
