Hydrostat 165 Need help
11 replies to this topic
#1 volsspartan75 OFFLINE
volsspartan75
  • 6 posts
Posted September 26, 2016 - 10:18 PM
Received a free John Deere Hydrostat 165 tractor.
Just a few problems right off the bat,  since I have had the tractor I have not been able to get it to turn over or anything.
Looking for help!
Checked the battery by purchasing a new battery.
Still nothing
#2 stiemmy OFFLINE
stiemmy
  • 2,044 Thanks
  • 1,558 posts
Posted September 27, 2016 - 02:01 AM
Reading the battery voltage on a meter is the CHEAPEST way to see if a battery is working, then load testing it will verify holding a charge
My goodness, if mechanics worked that way,they'd ALL be broke!
Check you're cable connetions, and clean as needed!;)
#3 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 9,024 Thanks
  • 4,993 posts
Posted September 27, 2016 - 02:32 AM
Then, with the PTO OFF, parking brake set jump the battery side of the solenoid to the little wire connection (Start wire) and see if it cranks then.  If so, you have a keyswitch or Safety interlock issue
#4 glgrumpy ONLINE
  • 7,409 Thanks
  • 7,050 posts
Posted September 27, 2016 - 06:36 AM
Are you aware of pushing the pedal to start? The clutch/brake or whatever it may be called on yours.  The pto switch off?  Seat switch still funcional, YOU have to be in Seat to make it be on, can't start standing beside tractor. There is maybe a back-up button to press when backing up with mower on?  Is that stuck? Lots of things on the new GT's to look at.
#5 Cat385B ONLINE
    Therapy CAT
  • 12,643 Thanks
  • 9,350 posts
Posted September 27, 2016 - 06:53 AM
Does it click at all when you turn the key? Lights on at the dashboard?
#6 jd.rasentrac ONLINE
jd.rasentrac
  • 4,585 Thanks
  • 4,093 posts
Posted September 27, 2016 - 08:51 AM
Have you checked the fuel tank, too, and the hoses, the filter, the...
And now:   :welcometogttalk:
#7 volsspartan75 OFFLINE
volsspartan75
  • 6 posts
Posted September 27, 2016 - 03:42 PM
It does nothing when I turn the key at all
#8 volsspartan75 OFFLINE
volsspartan75
  • 6 posts
yes aware of the pedal, this tractor is an old 1986 hydrostat 165 john deere
#9 volsspartan75 OFFLINE
volsspartan75
  • 6 posts
Posted September 27, 2016 - 03:43 PM
There is gas in the tank,  the machine doesn't turn over at all nothing happens when I turn the key
#10 volsspartan75 OFFLINE
volsspartan75
  • 6 posts
Posted September 29, 2016 - 06:13 PM
So I see everyone using some type of relay?  what is the relay for and where can I pick up one at?
#11 Cat385B ONLINE
    Therapy CAT
  • 12,643 Thanks
  • 9,350 posts
Posted September 29, 2016 - 09:36 PM
The relay is for a starter improvement kit. Those models had a problem with getting full voltage to the starter. If you have no lights or power anywhere when you turn the key, you have other issues.
This is the improvement for the starter:
  • volsspartan75 said thank you
#12 volsspartan75 OFFLINE
volsspartan75
  • 6 posts
Posted September 29, 2016 - 10:22 PM
Yeah I think tomorrow I am going to spend the day tearing the tractor apart
And kinda start over at the beginning of the wiring to see if I can get anywhere with it......
