Hey Mr. Glgrumpy
9 replies to this topic
#1 SNUFFY OFFLINE
SNUFFY
  • 187 Thanks
  • 268 posts
Posted September 26, 2016 - 07:20 PM
I`ve seen your avatar and saw the Moline on it ....thought it was a PK but wasn`t sure. I`m wondering if you could post up some pics of it. I`m real curious to see how you done it. Since I`m doing mine different too you done some things I`ve had on my mind....no tunnel...those are some good lookin` fenders too.
I`d just like to see some closer up pics of what you have done
The more pics the better Please !!
#2 glgrumpy OFFLINE
  • 8,602 Thanks
  • 7,906 posts
Posted September 27, 2016 - 03:08 AM
Have to do new, most I've deleted. Wheelhorse D series fender tops. Made cage structure to hold and tank too. Floor just diamond plate bolted to frame. Rest is stock. Woops! Battery on side in front too.
#3 MH81 OFFLINE
Posted September 27, 2016 - 06:49 AM
GL, Did you post them here before you deleted them?
#4 glgrumpy OFFLINE
  • 8,602 Thanks
  • 7,906 posts
Posted September 27, 2016 - 07:03 AM
Not sure if I was on here then,  been awhile since I made it. I'm not really sure if any postings here or not. Might be some on the Yahoo Group forum, been there for long time and have some old folders with pictures of many items. Finding them might be another story, heh!
#5 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted September 27, 2016 - 07:51 AM
I found this picture.
  • olcowhand, Alc and Sawdust have said thanks
#6 SNUFFY OFFLINE
SNUFFY
  • 187 Thanks
  • 268 posts
Posted September 27, 2016 - 10:23 AM
Not in a hurry GL...getting ready to start to do some final assembly on mine....Got sidetracked a little now trying to get my Case 444 Black Knight going after sitting no telling how long while waiting on some parts for the PK....
That is some kind of good looking machine Username posted.
#7 SNUFFY OFFLINE
SNUFFY
  • 187 Thanks
  • 268 posts
Posted September 27, 2016 - 10:24 AM
the battery was one of the things I was curious about
#8 glgrumpy OFFLINE
  • 8,602 Thanks
  • 7,906 posts
Posted September 29, 2016 - 04:59 PM
Well, yes, that is a nice PK Moline there in pix, but NOT mine for sure. Too clean and shiny, ha!
#9 glgrumpy OFFLINE
  • 8,602 Thanks
  • 7,906 posts
Posted September 29, 2016 - 07:49 PM
Well, went out tonight and took a few pix of the PK MM. Hope light is enough. I built a battery on right side near engine. Ground wire goes right to mount bolt for engine, and other goes under engine to the selinoid. They are a little shorter that way. This is smaller battery in physical size, but is a 340 CCA and is plenty big enough. I start it occasionally in winter in garage, and has only failed once. I hadn't been charging it in cold. Floor pan I had to cut out a couple spots to clear brake rods. Could have been shorter, but was trying to reach some holes already in frame to mount, so back a little farther. I cut around front to clear the trans drain and around the brake pedals. The fenders I built a little structure behind seat to hold them and the hydra tank mounts there also. With the tin off you lose the mount areas for tank and battery, thus the changes. I have a little longer bumper on front, but you don't notice. Other than that, pretty much stock parts on rest of it. I DID not get PK dash sticker and used Speedex type to label controls, they look good.
Edited by glgrumpy, September 29, 2016 - 08:05 PM.
#10 SNUFFY OFFLINE
SNUFFY
  • 187 Thanks
  • 268 posts
Posted September 30, 2016 - 07:07 AM
Thanks Grump.....I like what you have done.....gives me some ideas. I decided I didn`t need another mower early on and sold the deck and mule drive. I`m thinking about doing cultivators under the tractor with Hyd lift and maybe even less floor pan than you have.....just need a spot for your feet !! I got a set of new Ford 1500 fenders for my tractor and the old ones could maybe figure out to bob them somehow to fit.  Already have the PK fenders painted and ready though...
Thanks again for pics..... gives me some more ideas
