Poor spark - Not no spark.
poor spark
18 replies to this topic
#16 chieffan ONLINE
  • 11,372 Thanks
  • 7,118 posts
Posted September 27, 2016 - 07:32 AM
I am using an electronic ignition module. That bypasses the points and condenser.
I like to think it works better.
I use several modules on single cylinder engines but have to have a good coil for them to work.  Try a known good coil and see if your problem goes away.  Good luck.
#17 Endmill OFFLINE
Endmill
  • 8 Thanks
  • 13 posts
Posted September 27, 2016 - 06:19 PM
Hi Chieffan
Do you run them in series or parallel?
Thank you
Endmill
#18 Endmill OFFLINE
Endmill
  • 8 Thanks
  • 13 posts
Posted September 29, 2016 - 06:25 AM
It's a fact that if your coil gap isn't set right you will not get an adequate spark. I got it running great. I know that mice got under the cover of my engine. My guess is that the nest moved the old coil. When i replaced it, I did not have the the air gap set properly. I would like to thank-you all very much for your positive input. I am up and running just in time to put it into storage for the winter.
Thanks again
Endmill
  • MH81, Alc, Bruce Dorsi and 1 other said thanks
#19 Cvans ONLINE
  • 7,302 Thanks
  • 6,387 posts
Posted September 29, 2016 - 09:25 AM
Thanks for letting us know what you found out.
