ariens garden tillers qustion
10 replies to this topic
#1 KY hillbilly OFFLINE
KY hillbilly
  • 50 Thanks
  • 75 posts
Posted September 26, 2016 - 02:19 PM
Any one know anything about them? I found one with no engine for 100 bucks, I don't know the model or anything but it seams to be pretty heavy made. All cast tranmission has the 8in tractor style tires and front cast iron weight too.
Idk anything about them it looks like be a pretty good one to throw a hf engine on till I can find the parts for my tb horse.
  • Cvans said thank you
#2 boyscout862 OFFLINE
  • 13,692 Thanks
  • 9,475 posts
Posted September 26, 2016 - 02:43 PM
Ariens stuff has generally been pretty good quality. I would be very suspicious about the tiller not having an engine. It might have transmission problems and that is why the engine was taken off. Fix the Troybilt. We have the full rebuilding manual for Troybilt somewhere in our Manuals Section.  Good Luck, Rick
#3 KY hillbilly OFFLINE
KY hillbilly
  • 50 Thanks
  • 75 posts
Posted September 26, 2016 - 03:06 PM
The guy has a bunch of old tillers and stuff. Apparently he buys them and fixes them up to sell? Anyway he's story is that the engine went bad and the rest is good. I though about offering 50 for it.
Are they a branch of gravely? Only reason I ask is I got on ebay to see if there was much on there it came up ariens/gravely.
#4 shorty ONLINE
shorty
  • 5,921 Thanks
  • 5,453 posts
Posted September 26, 2016 - 03:54 PM
Ariens bought Gravely back in 80's or 90's. I never ran an Ariens tiller, but the rest of their equipment was heavy built.
#5 Kurtee OFFLINE
Kurtee
  • 594 Thanks
  • 473 posts
Posted September 26, 2016 - 07:31 PM
Ariens rear tines are as good as tillers get. I own 2 and for 100 bucks I would have another in a heart beat. Parts are available. This sounds like an older cast iron tranny and drive one which is better than the newer ones with aluminum housing. I have used Troybilts and prefer operating the Ariens. The first one I bought did lots of gardens with a 5 horse Tecumseh. I actually wore out the tines and engine and replaced them with new and am still using it. The second one I bought to take some load of the first one and has an 8 horse Kohler with reverse and swinging handlebars which I believe are over rated. I had to replace the bearings and seals in the tine gearbox. They have stopped building these which are infinitely better than what is available new. Buy it, fix it, use it while you fix the Troybilt and have 2.
#6 Cat385B ONLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted September 26, 2016 - 07:40 PM
If the Ariens is a rear-tine 'Rocket', it would be well worth fixing. I grew up on one like what Kurtee has, reverse and swinging handlebars. I would till the garden the long way, then put on the furrow sweep and go the short way ending with having the rows dug out for seed.
Edited by Cat385B, September 26, 2016 - 07:44 PM.
#7 KY hillbilly OFFLINE
KY hillbilly
  • 50 Thanks
  • 75 posts
Posted September 26, 2016 - 10:12 PM
I think it is a rocket just by Google it seeing they look the same. I think I'm going back and offering 50, by the looks of the picture iv seen I think there may be a pulley or too missing.
Is parts still available for them?
#8 steve b OFFLINE
steve b
  • 122 Thanks
  • 227 posts
Posted September 28, 2016 - 12:42 PM
Go get it. We had Troybilt and the 8 hp  Ariens tillers. I always thought the Ariens was the better tiller. It was tough and easier to handle.
  • KY hillbilly said thank you
#9 traktrjorj OFFLINE
traktrjorj
  • 51 Thanks
  • 30 posts
Posted November 27, 2016 - 08:16 PM
Well , it depends on which Ariens you have some were as tough as nails but I personally do not care for the newer Ariens Rocket rear tiller.  Not that it was not doing it's job but when it hit a root, it jumped or lunged about 2 foot forward taking my arms and leaving my shoulders behind. I was sore for a couple weeks on that experience and vowed to never run one again. This one I have: It does not lunge! It is a 1935 Ariens Model C.Ariens Mdl C 1935.jpg
  • Cat385B, Columbia236 and Clifford Bridgford have said thanks
#10 Cvans OFFLINE
  • 7,471 Thanks
  • 6,471 posts
Posted November 27, 2016 - 09:31 PM
I'll bet not. The thing could probably crawl over that propane tank and not even blink.
The Ariens we had was built like a tank. All cast iron and heavy, The only problem was the engine sets at an angle so the carb. float was hard to set. Seemed like it was either running rich or lean and sometimes changing in the middle of the job. That and the ground speed was kind of fast even in the lower gear. Changing pulley's would probably cure that.
#11 KY hillbilly OFFLINE
KY hillbilly
  • 50 Thanks
  • 75 posts
Posted November 29, 2016 - 01:42 PM
Well , it depends on which Ariens you have some were as tough as nails but I personally do not care for the newer Ariens Rocket rear tiller. Not that it was not doing it's job but when it hit a root, it jumped or lunged about 2 foot forward taking my arms and leaving my shoulders behind. I was sore for a couple weeks on that experience and vowed to never run one again. This one I have: It does not lunge! It is a 1935 Ariens Model C. Ariens Mdl C 1935.jpg
I'd love to have one of those but I can't figure where there all hid at lol
Edited by KY hillbilly, November 29, 2016 - 01:43 PM.
