Ariens / Gravely 12" 5 hole rims
9 replies to this topic
#1 Gillis.jim OFFLINE
Gillis.jim
  • 277 Thanks
  • 159 posts
Posted September 24, 2016 - 01:13 PM
Hey everyone, winter is approaching here in the Maritime provinces of Canada and I'm looking to get my hands on a second set of 12" five hole rims to fit another set of tires for my Ariens S-16.
I have 5 sets of tires that I could put on the old girl but only one set of rims. I've only ever changed them once and I am not looking forward to the next tire change!
If you know of some or if you have some info on what other brands used the same rims I would really appreciate your help!
Thanks -Jim
#2 KennyP OFFLINE
  • 29,411 Thanks
  • 40,401 posts
Posted September 24, 2016 - 01:27 PM
First thing, what is the width. Next is the offset.  Lots of wheels out there, but they may not work with your machine!
  • boyscout862 and Gillis.jim have said thanks
#3 Gillis.jim OFFLINE
Gillis.jim
  • 277 Thanks
  • 159 posts
Posted September 24, 2016 - 02:50 PM
Oops that wasn't very smart of me. They are 10.5" wide. The offset I'm not sure about however it shouldn't matter I can make them work if the offset is different
#4 Gillis.jim OFFLINE
Gillis.jim
  • 277 Thanks
  • 159 posts
Posted September 24, 2016 - 03:00 PM
Stud to next stud is 6.6 cm or 2 5/8 inches (5 bolt pattern) stud to stud across is 4 5/16 inches or 11 cm
#5 KennyP OFFLINE
  • 29,411 Thanks
  • 40,401 posts
Posted September 24, 2016 - 03:29 PM
Sounds like a 4.5 X 5 bolt pattern which is normal. Offset is the distance from where they bolt up to the inside edge of the wheel!
Offset!
#6 Gillis.jim OFFLINE
Gillis.jim
  • 277 Thanks
  • 159 posts
Posted September 24, 2016 - 03:39 PM
Offset!
Ok great. I will measure when I get back to the shop!!
#7 chieffan ONLINE
  • 6,354 Thanks
  • 4,594 posts
Posted September 24, 2016 - 04:32 PM
You should be able to come up with a couple rims without to much trouble.  My White GT has 15" X 4 bolt rims.  I think the only other GT that had those size rims was a Case and possibly a Wheel Horse.  VERY hard to find.
#8 shorty ONLINE
shorty
  • 3,890 Thanks
  • 4,193 posts
Posted September 24, 2016 - 04:56 PM
It should be the normal 4.5" ×5 pattern. Offset around 1.5" from center. Designed to run in the narrow spacing. I like it in the wide stance.
Edited by shorty, September 24, 2016 - 04:56 PM.
  • 1964Deere and Gillis.jim have said thanks
#9 Gillis.jim OFFLINE
Gillis.jim
  • 277 Thanks
  • 159 posts
Posted September 24, 2016 - 07:27 PM
Yeah that's what they are shorty thanks!
  • shorty said thank you
#10 dodge trucker ONLINE
dodge trucker
  • 1,495 Thanks
  • 1,943 posts
Posted September 25, 2016 - 08:29 AM
I bolted a set from a Sears Suburban right onto my New Holland S14 ..... my Cub cadet ones fit too.
