Best place to buy tubes?
7 replies to this topic
#1 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,798 Thanks
  • 1,003 posts
Posted September 23, 2016 - 10:42 PM
I just got a set of Carlisle Tru-Powers for my 140, cheap. I want to tube them since I have no idea what their history is like. Two questions - where is the best place to buy a tube? I don't necessarily want the cheapest, I'll pay a bit more for quality.
Second, what type of stem do I need? I have no idea what TR13 or any of the other designations mean! Thanks!
#2 boyscout862 ONLINE
  • 12,833 Thanks
  • 9,160 posts
Posted September 23, 2016 - 11:22 PM
I've been using Slime instead of tubes for 4 years now. Only failled twice. Can be messy. I break the bead and pump it into the tire, never through the valve stem. It gums up the valve stem. I use new automotive valve stems on tractor tires. They are just the standard short size that are sold in bulk at swap meets. Good Luck, Rick
  • SupplySergeant said thank you
#3 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted September 24, 2016 - 01:10 AM
Tsc, farm and fleet, fleet farm, or any tire store. If they ain't got em, they can get em!
#4 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,311 Thanks
  • 4,948 posts
Posted September 24, 2016 - 03:39 AM
I found that my local Goodyear dealer has tubes cheaper than TSC, Orscheln's, or Tractor Supply.
  • Alc, boyscout862 and SupplySergeant have said thanks
#5 Trav1s ONLINE
Trav1s
  • 3,303 Thanks
  • 4,358 posts
Posted September 24, 2016 - 06:47 AM
www.millertire.com is my favorite place - if they don't have it then you don't need it
  • WHdbJD, boyscout862 and SupplySergeant have said thanks
#6 chieffan ONLINE
  • 10,119 Thanks
  • 6,625 posts
Posted September 24, 2016 - 07:23 AM
I have had good luck with slime also.  I put mine in through the valve steam and it is going to get into the valve stem anyway.  Just shoot some air in before you install the core and be sure you use enough slime.  It is a little messy if you have to put a patch in later but it washes out with water real easy.  Tire shops just like to complain about it as it beats them out a $20 tire patch.
  • boyscout862 and SupplySergeant have said thanks
#7 ericjr16 ONLINE
ericjr16
  • 1,051 Thanks
  • 575 posts
Posted September 24, 2016 - 08:30 AM
I get mine online from agrisupply.com. Been great price and quality!
  • Trav1s and SupplySergeant have said thanks
#8 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,798 Thanks
  • 1,003 posts
Posted September 24, 2016 - 10:33 AM
Thanks, everybody! I have used Slime, and it has helped when I run through black locust sprouts and stab through the sidewall. Unfortunately I don't think it works too well with loaded tires, and this is my plow tractor. I'll stop by the Goodyear after work Monday, armed with prices from the online sullpiers you've pointed out. Thanks!
