Kubota d950 3cyl repower
9 replies to this topic
#1 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted September 23, 2016 - 08:49 AM
I have this 22-23 hp diesel that I'm dropping in a garden tractor. It fits very well into my frame. My question is on radiators. I am going to be using this tractor to plow in spring & fall only. I have limited space like most of you know, but I want something that will cool this motor. Please let me know what your using for radiators and electric fans. My current space availability id like to stay in is 10"x18" overall
  • chieffan said thank you
#2 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted September 23, 2016 - 04:32 PM
The original radiator was probably the minimum size that you need. What tractor are you going to put it in? Good Luck, Rick
#3 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted September 23, 2016 - 04:55 PM
A new holland. But not necessarily have seen guys use Honda radiators or 4 wheeler radiators in customs. Also depends on usage. Plowing in the spring or fall should be a little cooler than mowing in the heat of summer(motor came off golf course mower) with less debris getting in the fins
Edited by 1964Deere, September 23, 2016 - 04:58 PM.
#4 secondtry OFFLINE
secondtry
  • 2,158 Thanks
  • 1,531 posts
Posted September 23, 2016 - 05:01 PM
When considering radiator size the number of cores needs to be considered also. Add a core and the size can be reduced. Don
#5 olcowhand ONLINE
  • 42,897 Thanks
  • 31,941 posts
Posted September 23, 2016 - 07:12 PM
I used a 2 core Honda Civic/Del Sol radiator with my Kubota D1005 with engine driven fan and it never gets hot, but it measures 14W x 18" tall.
  • Cvans, shorty and Dieselcubmike have said thanks
#6 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted September 23, 2016 - 10:27 PM
I have one from a honda del sol/civic from CR racing on ebay. Cheap and easy to install and lightweight as well. I have a 14 inch fan on mine currently but our applications are different  :thumbs:
#7 shorty ONLINE
shorty
  • 5,833 Thanks
  • 5,414 posts
Posted September 24, 2016 - 02:24 PM
That's the one I was thinking of Brad. But at 14 wide, you would almost need a shoehorn to slip it in the front. About 12" wide would be much easier.
#8 olcowhand ONLINE
  • 42,897 Thanks
  • 31,941 posts
Posted September 24, 2016 - 03:19 PM
Here's what should work for you.  The last one I bought but haven't used yet is a radiator for a Mini-Cooper.  It's only 10 1/4" wide x 15 1/4" tall and 2" thick.  You can find them on Ebay in 2 core and 3 core versions.  I think even the 2 core would do if using an electric fan as they really move the air.  I put a 190* thermostat inline to operate my fans and they do cycle off a lot, so even the smaller 2 core oughta keep the engine heat at bay, but the fan may cycle on longer.  There are differences between companies as to the drain plug configuration, so be aware when looking to buy.
  • 1964Deere, KennyP, Cvans and 1 other said thanks
#9 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted September 25, 2016 - 01:20 PM
Thanks olcowhand
  • olcowhand said thank you
#10 DaveBb OFFLINE
DaveBb
  • 405 Thanks
  • 173 posts
Posted November 20, 2016 - 01:54 PM
Remember if your replacing a Kohler the D950 turns the apposite way..
