Simplicity 7790 its at the shop
10 replies to this topic
#1 MNGB ONLINE
MNGB
  • 2,491 Thanks
  • 1,522 posts
Posted September 22, 2016 - 06:05 PM
Hi, well the 7790 now has a new home , its now at my shop, got it and the attachments this afternoon. Got a tiller a dozer / plow blade and a mower deck with it, so the fun will begin in a few days.
100_0584.JPG 100_0585.JPG 100_0586.JPG 100_0593.JPG 100_0594.JPG 100_0583.JPG
  • coldone, Alc, KennyP and 4 others have said thanks
#2 KennyP OFFLINE
  • 40,130 Thanks
  • 46,764 posts
Posted September 22, 2016 - 06:13 PM
Great news to hear! Have fun with it!
  • boyscout862 and MNGB have said thanks
#3 HANKG ONLINE
HANKG
  • 6,536 Thanks
  • 3,507 posts
Posted September 23, 2016 - 09:54 AM
Nice machine best of luck.
  • MNGB said thank you
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted September 23, 2016 - 02:26 PM
NICE!!!
#5 MNGB ONLINE
MNGB
  • 2,491 Thanks
  • 1,522 posts
Posted September 23, 2016 - 07:37 PM
Hi, got the Simplicity off the trailer and in the shop this morning, didn't really do much to it just looked it over some, but I do have a question for those with some experience with this diesel or any diesel engine I'm thinking about removing the injectors that way the engine should crank over easier making it easier ti try priming the injector pump would this be a viable thing to do?
#6 KennyP OFFLINE
  • 40,130 Thanks
  • 46,764 posts
Posted September 24, 2016 - 05:20 AM
Most folks just loosen the fuel lines to them.
#7 haykarenhardy OFFLINE
haykarenhardy
  • 55 Thanks
  • 29 posts
Posted September 24, 2016 - 05:51 AM
If Your tractor has the stock lift pump there is a prime handle you can use to prime the system. the lift pump; is in front of the injection pump. Also a bleed screw on the fuel filter. The only time I had to crack the fuel lines to prime was when I replaced the rubber O rings in the injectors, they have a habit of drying out and leaking.
Stan
#8 MNGB ONLINE
MNGB
  • 2,491 Thanks
  • 1,522 posts
Posted September 28, 2016 - 12:46 PM
Hi well I looked the 7790 over a bit, tried turning the engine over by hand to make sure it wasn't stuck and it turned so I connected a set of jumper cable and tried the starter it cranked over so that was good.  Looked over the fuel delivery system, looked and looked can not find a priming lever on the lift pump, found the bleed screw in the top of the filter reconnected the injector lines and that's as far as I got. Will have to figure out witch way to go from here, (besides putting fuel in the tank) remove the injector so the engine cranks easier, or maybe install an electric lift pump to get fuel to the injector pump?
#9 KennyP OFFLINE
  • 40,130 Thanks
  • 46,764 posts
Posted September 28, 2016 - 04:11 PM
Some pics may help folks help you!
#10 coldone OFFLINE
coldone
  • 1,664 Thanks
  • 1,683 posts
Posted September 28, 2016 - 05:27 PM
Here is a vid I did a few years ago with my lombardinis,maybe it will help.
I had to take my lift pump apart and clean it, the valves were stuck. I primed my by turning it over with the injectors in the motor. I did have to take them out and "refresh" them because they were fullof crude too. Once they where cleaned I put the fuel lines back on them and turned it over to see the spray pattern.
#11 MNGB ONLINE
MNGB
  • 2,491 Thanks
  • 1,522 posts
Posted September 28, 2016 - 06:01 PM
Hi coldone, thanks very for the video and information, I'll get into to it more in the near future I do appreciate the help and tips from all fellow members.
