Engine Rebuild... OOOPSIE!
16 replies to this topic
#16 theck4291 OFFLINE
theck4291
  • 3 Thanks
  • 15 posts
Posted September 24, 2016 - 07:42 AM
I was lucky enough that it broke right behind the adjustment bolt, leaving the stud easy for me to remove... I PROBABLY messed up at the part where I was unaware that there was a torx head on the adjustment bolt and never held that... so yeaaaaa....
Let me get this straight, because its only 8:39 am right now, I was up til 5 so my brain is not fully functional.... If I have the head completely off.... and I am looking at the piston in the cylinder, top dead center will be when the piston is pushed all the way out and I can not see any of the cylinder, correct? thanks!
#17 EricFromPa ONLINE
EricFromPa
  • 3,523 Thanks
  • 3,070 posts
Posted September 24, 2016 - 10:50 AM
Yes Piston will be the whole way up.
Torx bit is in the center of the rocker nut.You Hold the Torx bit firmly and tighten/loosen the rocker nut just like a jam nut.They make a tool for it but you can use a 10mm wrench and a T20 Torx bit driver.
This tool makes them a little easier to set.Slide your Torx driver down inside and your good to go.
https://www.amazon.c...g=toolmonger-20
