My wife the mechanic
11 replies to this topic
#1 Alc ONLINE
  • 7,126 Thanks
  • 7,530 posts
Posted September 20, 2016 - 07:57 PM
Finishing up the 3400 Ford utility tractor that I had sitting for years and finally got running last fall . Decided to paint it and fix some issues figuring it would be done early spring . New ignition switch and starter solenoid last night so tonight was going to be easy . Give it a shot of starting fluid to make sure she fires off then put gas it . Everything ready ,shot of starting fluid ,, nothing , checked for spark , nothing , wire going from coil to distributor had cracked insulation and wires almost broke through . Fix that still just a weak to no spark . Took the cap off to check the points , gap good , cleaned with brake clean everything looked good ( keep that in mind ). Still no go , the wife comes out ,told her it has weak spark , she said " bad coil " maybe but put a new one on a few years ago in a failed attempt to get started . By this time even the little battery charger wasn't keeping up so I got another battery to jump this one too . Now we got her spinning good ,,, still a weak spark. Now the wife says " did you check the points?" yep I said " how about the condenser ? ,, Silence,,,,,,aw crap! Last fall when I was trying different things to get it started I mounted the condenser externally and after moving the tractor closer to the garage I removed all the temporary wires clips ext. Went into the garage , got the condenser that was sitting on the work bench , installed it and one shot of starting fluid it fired off . So even though I looked right where it should have been ,next to the points it didn't dawn on me it was missing . Thanks to my wife of 31 years
  • daytime dave, Gtractor, Bruce Dorsi and 18 others have said thanks
#2 daytime dave OFFLINE
  • 4,935 Thanks
  • 6,579 posts
Posted September 20, 2016 - 08:01 PM
That was a nice story of team work Al.  Thanks for sharing it.
#3 lyall OFFLINE
lyall
  • 2,171 Thanks
  • 1,573 posts
Posted September 20, 2016 - 08:03 PM
she is a keeper
  • Alc and Titus have said thanks
#4 Cvans ONLINE
  • 7,075 Thanks
  • 6,292 posts
Posted September 20, 2016 - 08:28 PM
Good story. Please tell here I really enjoyed it.
Most young people don't know what a set of points is much less where they go.
Edited by Cvans, September 20, 2016 - 08:28 PM.
  • KennyP and chris m have said thanks
#5 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,648 Thanks
  • 5,046 posts
Posted September 20, 2016 - 08:44 PM
Don't feel bad.  I didn't catch a missing rotor button in a distributor recently - TWICE
It was mega-super hot and the sweat was in my eyes. That's my s'cuse anyhow.  :(
Glad you got-er goin.
  • Alc and Cvans have said thanks
#6 HDWildBill OFFLINE
  • 8,978 Thanks
Posted September 20, 2016 - 09:08 PM
Don't feel bad, My wife has done the same to me.
#7 KennyP OFFLINE
  • 40,130 Thanks
  • 46,764 posts
Posted September 21, 2016 - 06:20 AM
Way to go Mrs. Alc! Glad she has the knowledge to help!
#8 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted September 21, 2016 - 07:18 AM
Good that she could help out. My wife has no idea what points are; much less a condenser.
#9 Alc ONLINE
  • 7,126 Thanks
  • 7,530 posts
Posted September 21, 2016 - 07:49 AM
 I don't think my wife would know  the difference between the points and condenser but does know there are in my old tractors and if there not working right they don't get spark .
  • KennyP, Cvans, HDWildBill and 1 other said thanks
#10 HANKG ONLINE
HANKG
  • 6,536 Thanks
  • 3,507 posts
Posted September 21, 2016 - 07:55 AM
Mary's a smart lady Al.
#11 HDWildBill OFFLINE
  • 8,978 Thanks
Posted September 21, 2016 - 08:56 AM
My wife couldn't install anything but she has heard me talk enough about T/S and knows there is usually a sequence to follow or check.  So she is my check list and it works.  I've also found that by describing to her what the problem is and what I have done a lot of times, like you ALC, I will see something I didn't see previously.
Even when I was working and programming computers I would be stuck on a bug and I would walk her through the code and the proverbial question would come out, either does case matter or does spelling count.  There would be my problem.  Usually one letter out of place.
#12 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted September 21, 2016 - 11:53 AM
:thumbs:
