455 Hydraulic steering cylinder repair?
10 replies to this topic
#1 Alberta Bolens OFFLINE
Alberta Bolens
  • 905 Thanks
  • 378 posts
Posted September 18, 2016 - 08:54 PM
Hi My 455 power steering cylinder is pouring oil out of it.  From what I see they cannot be rebuilt or new seals put in.  Is there a trick that someone has?
Other than paying big $$ for new one and even the ones I find on Ebay are not cheap.  Anyone know of an aftermarket cylinder out there?
Thanks
#2 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted September 18, 2016 - 09:00 PM
I have never seen a cylinder that cannot be rebuilt. Maybe some cheap Chinese junk but nothing that is mounted to any decent tractor. You just need to find a parts breakdown and it should be fairly straight forward from there. If that is the same cessna unit used on the 400 then unless the housing is cracked, and most are, you can simply buy the oring and scrubbers and it is very easy to rebuild. If it is the cylinder I mentioned I just rebuilt on so can help if you need.
#3 Alberta Bolens OFFLINE
Alberta Bolens
  • 905 Thanks
  • 378 posts
Posted September 18, 2016 - 09:07 PM
I been looking for rebuild kits have had no luck so far.  Going to pull it off and dig into it see what I find.  Thanks
#4 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted September 18, 2016 - 09:15 PM
http://www.ebay.com/...jgAAOSwpDdVPlgt
#5 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted September 18, 2016 - 09:22 PM
That is certainly not the cylinder I was thinking of but can help if you need anyhow. Best of luck tearing it apart seems pretty straight forward.
#6 ducky OFFLINE
  • 1,988 Thanks
  • 4,107 posts
Posted September 18, 2016 - 09:45 PM
I just checked the 455 Manuals I have and can not find any instructions to repair the steering cylinder.
Take it to a reputable hydraulic repair shop and they can take care of it for you.
Some of this stuff is made to not be repaired and the manufacturer will charge you Deere-ly for the new part.
A hydraulic shop can cut it apart, reseal and weld it back together at a much lower cost. They will have or can get the seals it needs.
#7 pidjones OFFLINE
pidjones
  • 58 Thanks
  • 51 posts
Posted September 19, 2016 - 05:43 AM
Have you tried a power equipment dealer? Most places that repair hydraulics for bulldozers, etc. should be able to give you an idea if it is rebuildable.
#8 olcowhand ONLINE
  • 42,382 Thanks
  • 31,798 posts
Posted September 19, 2016 - 08:13 AM
 Don is right, it can be rebuilt.  I've cut ends off myself, rebuilt, then welded the end cap back on.
  • Alc and Leonard VanCamp have said thanks
#9 Alberta Bolens OFFLINE
Alberta Bolens
  • 905 Thanks
  • 378 posts
Posted September 19, 2016 - 10:46 PM
I looked at it tonight and it would have to be cut apart.  Hmm.  So, is it just me.  Or does not the thought of cutting would expose the hydro system to a hole wack of contimnation.  I guess a good hydralic shop would be equipped for that, thinking that still going run couple hundred $$.
Is there any aftermarket cylinders avaiable?  Cheaper that OEM.  I do see few used ones on Ebay.
Thanks
#10 scuffy727 OFFLINE
scuffy727
  • 131 Thanks
  • 92 posts
Posted December 20, 2016 - 08:55 PM
I know this is an old post, but my 445 cylinder was leaking the same way and I took it to a local hydraulic cylinder shop.  The shop cut the cylinder and installed new orings and rewelded  for $75.  It was not as expensive as I was anticipating.
#11 JD318420 OFFLINE
JD318420
  • 65 Thanks
  • 97 posts
Posted December 20, 2016 - 11:33 PM
Hydraulic shops can repair them, they even have the proper equipment to make sure any contamination is flushed out. Many large companies had their own shops, now everything is sent out to reputable shops that will pickup and deliver.
