22hp Briggs Intek V twin acts like its loading up ?
7 replies to this topic
#1 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,605 Thanks
  • 1,306 posts
Posted September 17, 2016 - 02:24 PM
I have a 22 Briggs Intek V twin in a 1998 Craftsman mower tractor that acts like its loading up when you run it. It don't want to run wide open. If you throttle it way down it will try to straighten up but still doesn't want to take fuel. If you engage the mower deck it will kill the engine. Any of you guys that mess with these newer engines have any ideas ? I drug it home this way.
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted September 17, 2016 - 03:12 PM
Smoking? Sounds lean to me
  • rustyoldjunk said thank you
#3 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,195 Thanks
  • 5,669 posts
Posted September 17, 2016 - 03:30 PM
Pull & read the plugs..  White = lean, black = fouled..  Sometimes swapping them helps with a firing problem..  Describing the symptoms is one thing but checking the thing out is better way to help folks help you more.  A sticking fuel solenoid or other fuel supply problem or even a bad head gasket..  Just a few things to consider..
#4 tater195 ONLINE
tater195
  • 2,074 Thanks
  • 1,378 posts
Posted September 17, 2016 - 04:12 PM
If you have an IR temp gun, check the temp of the heads. I suspect a dead hole due to a valve problem, but a bad plug may not be too far off either.
#5 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,605 Thanks
  • 1,306 posts
Posted September 18, 2016 - 12:14 PM
I did already check the plugs and they comfirmed rich Being black and carboned up some.
#6 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,605 Thanks
  • 1,306 posts
Posted September 18, 2016 - 12:16 PM
Pouring a tad of gas into the carb loads it up worse.
#7 SimplyRad OFFLINE
SimplyRad
  • 1,018 Thanks
  • 785 posts
Posted September 18, 2016 - 01:21 PM
I know this may off base but I had a 72 Dodge that would load up and it was the choke sticking. Just a thought but worth a check.
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted September 21, 2016 - 09:53 AM
New plugs?
