Cub 782 Engine Swap
3 replies to this topic
#1 Walkinman1 OFFLINE
Walkinman1
  • 767 Thanks
  • 583 posts
Posted September 17, 2016 - 12:10 PM
I know this topic has been covered at length but I can't seem to find what I'm looking for and I'm hoping someone can help direct me...
Has anyone swapped a single cylinder Kohler into a 782? I know anything CAN be done but I'd like to keep sheet metal intact as much as possible... I have a K301 that I was taking a few measurements from and it appears that it may fit although it would be pretty tight (didn't realize how big those singles are compared to the KT17 twins).
On a side note: I've found many examples of swapping other twins into a 782 but if I'm gonna spend the money to do that I'll probably just rebuild the engine in it now...
#2 IHCubGuy ONLINE
IHCubGuy
  • 1,516 Thanks
  • 1,592 posts
Posted September 17, 2016 - 12:37 PM
That 12hp should fit in there with no problems.  You will basically be making it into a model 1282.  That was a single cylinder 12hp.
#3 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted September 17, 2016 - 03:08 PM
As long as its a 12hp with a gear starter. If its a starter gen style the side cover wont fit without cutting out a portion where the st/gen is and a lot of rewiring.
#4 Walkinman1 OFFLINE
Walkinman1
  • 767 Thanks
  • 583 posts
Posted September 17, 2016 - 03:22 PM
Thanks guys, I wasn't sure if the 1282 was essentially the same or not. The one I have is a starter-gen style and while the wiring doesn't scare me at all I'd rather not have to cut the side panel and that's what I was afraid of...
