Sears SS16 Onan will not charge battery
sears ss16
7 replies to this topic
#1 Gary from Muleshoe ONLINE
Gary from Muleshoe
  • 65 Thanks
  • 118 posts
Posted September 16, 2016 - 03:36 PM
I have checked all output from the stater, it is 33 vac, full throttle, put new regulator on, grounded it well with a ground wire, still will not charge. Where do I need to go next? Chieffan has been a big help for me on this already. I am wondering if the stater is putting out to much voltage?
#2 Titus ONLINE
Titus
    Bush Hog Hoarder
  • 1,835 Thanks
  • 2,330 posts
Posted September 16, 2016 - 03:44 PM
How old is the battery?
#3 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted September 16, 2016 - 04:07 PM
If this is a 3-terminal regulator turn the ignition key to the RUN position with the engine not running.
Measure the voltage across the battery posts.
Now move the red test lead to the DC terminal on the regulator. You should have the same voltage reading. If you don't the path the charge current takes to get to the battery is compromised.
This type of regulator must see battery voltage before it can regulate current. The battery voltage turns them on so to speak.
Garry
Edited by GWest, September 16, 2016 - 04:13 PM.
#4 jms180 ONLINE
jms180
  • 1,472 Thanks
  • 1,542 posts
Posted September 16, 2016 - 06:35 PM
I agree with Garry could be open circuit before current gets to battery maybe bad switch
#5 olcowhand ONLINE
  • 40,341 Thanks
  • 31,169 posts
Posted September 16, 2016 - 07:02 PM
When you turn the key on, the wire from the key switch going to the regulator should read battery voltage.  If it isn't, then somewhere between there & battery is a broken circuit.  Your AC voltage from the stator is fine.
#6 Gary from Muleshoe ONLINE
Gary from Muleshoe
  • 65 Thanks
  • 118 posts
Posted September 16, 2016 - 09:16 PM
Thanks guys, I will check that out in tomorrow.
Sent from my SM-G900P using Tapatalk
  • olcowhand said thank you
#7 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted September 17, 2016 - 06:57 AM
I should have included that not all models use the ignition switch for the charging circuit in case you go there looking for it and it is not there. If it is there the key must be in the RUN position to connect it to the battery.
Some models have the +DC wire going directly to the battery through a fuse and possibly tapped in at the starter solenoid battery cable.
The Onan's on the Wheel Horse tractors have a 20 amp stator and use a 30 amp fuse. Don't know if they ever used any other stator size in other applications.
Garry
Edited by GWest, September 17, 2016 - 07:01 AM.
#8 Gary from Muleshoe ONLINE
Gary from Muleshoe
  • 65 Thanks
  • 118 posts
Posted September 19, 2016 - 09:02 PM
I did some more checking tonight and there is no voltage between battery and regulator. Also with engine running full throttle regulator is on putting out 10 vdc with wire to switch disconnected and connected.
Also tagged with one or more of these keywords: sears ss16
