Volt meter
17 replies to this topic
#1 CraftsmanGT OFFLINE
CraftsmanGT
  • 369 Thanks
  • 321 posts
Posted September 15, 2016 - 06:53 PM
Need a hand hooking up a volt meter in place of the ammeter on my Bolens 1000. Thanks.
#2 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1692 Thanks
  • 1148 posts
Posted September 15, 2016 - 07:40 PM
  Connect the two wires that went to the ammeter together, else it won't charge the batt. If it is an inductive ammeter just cut the coil the the wire runs thru off it  You can run a small wire from the switch or the + batt post to get 12 volts to the voltmeter and make sure the meter has a good ground.
                                     Mike
Edited by ol' stonebreaker, September 15, 2016 - 07:43 PM.
  • CraftsmanGT said thank you
#3 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 8073 Thanks
  • 4777 posts
Posted September 15, 2016 - 07:43 PM
Like said above.... Twist Amp meter wires together, Connect the Volt meter + there, and the Volt meter - to ground.
               | Where the Amp meter was.
               v
Batt ------X------ Charge
               |  Volt Meter +
             (V)
               |   Volt Meter -
        Ground
Edited by larrybl, September 15, 2016 - 07:46 PM.
  • CraftsmanGT and crazy4bolens have said thanks
#4 CraftsmanGT OFFLINE
CraftsmanGT
  • 369 Thanks
  • 321 posts
Posted September 15, 2016 - 08:17 PM
Tried that and it works but is always reading, tried the ground to the key switch and nothing
#5 CraftsmanGT OFFLINE
CraftsmanGT
  • 369 Thanks
  • 321 posts
Posted September 15, 2016 - 08:19 PM
#6 MiCarl ONLINE
MiCarl
  • 2660 Thanks
  • 1322 posts
Posted September 15, 2016 - 08:35 PM
The diagram you posted has no place for a switched volt meter.  You need a switched (+) on the ignition switch.
In this diagram the only switched lead is the ground to kill the ignition.
#7 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 8073 Thanks
  • 4777 posts
Posted September 15, 2016 - 08:38 PM
That is a funky diagram. Any info on the key switch connector?
#8 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 8073 Thanks
  • 4777 posts
Posted September 15, 2016 - 08:42 PM
I like making reasonable modifications, but some times it is best to stay with the original configuration.
#9 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1692 Thanks
  • 1148 posts
Posted September 15, 2016 - 09:26 PM
  With the meter reading all the time I imagine it would take a loooong time to run the batt down.
                                                Mike
#10 CraftsmanGT OFFLINE
CraftsmanGT
  • 369 Thanks
  • 321 posts
Posted September 15, 2016 - 09:33 PM
It's a two prong on/off.
#11 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 8073 Thanks
  • 4777 posts
Posted September 15, 2016 - 09:37 PM
What does it turn on and off?
#12 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5116 Thanks
  • 2908 posts
Posted September 15, 2016 - 09:54 PM
I believe the original switch had only one terminal.
A wire from the ignition primary is connected to the switch terminal.
In the "ON" position there is no continuity between the terminal and the switch case.
In the "OFF" position, the terminal is connected to the switch case which is grounded, shorting the ignition primary to ground.
#13 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 8073 Thanks
  • 4777 posts
Posted September 15, 2016 - 10:00 PM
Then to add the volt meter as previously discussed you will need to add a on/off switch to the meter to turn it off.
#14 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1692 Thanks
  • 1148 posts
Posted September 15, 2016 - 10:11 PM
  Unless you're concerned about keeping things original you could install a GT ignition switch that would ground the mag when turned off and furnish power to the meter when turned on. Or as Larry said install a toggle switch for the meter and it won't hurt a thing if you forget to turn it on.
                                            Mike
#15 MiCarl ONLINE
MiCarl
  • 2660 Thanks
  • 1322 posts
Posted September 16, 2016 - 06:38 AM
I can see one other option:
Replace the ammeter with a diode and hook the volt meter to the "B" terminal on the voltage regulator.  The problem is this set up would only show you charging voltage, when the engine isn't running (or if the charging system fails) it'll just read 0.  It wouldn't tell you anything about the condition of the battery.
Edited by MiCarl, September 16, 2016 - 06:39 AM.
