i dont get this. when i checked fliud level it was good.its been leaking fliud from vent tube. it must only do it when its parked, never see any drips on floor. i moved this thing less than 20 feet, parked it and look at the puddle! whats up with this thing?
SEARS SUPER 12 HYDRO
#1
OFFLINE
Posted September 15, 2016 - 02:30 PM
#2
ONLINE
Posted September 15, 2016 - 02:40 PM
Need to show where it came from. Don
Edited by secondtry, September 15, 2016 - 02:40 PM.
- Xrperry said thank you
#3
OFFLINE
Posted September 15, 2016 - 03:25 PM
came from vent tube, the only thing under it thats wet.
#4
OFFLINE
Posted September 15, 2016 - 03:42 PM
Did you drive it 20 feet or did you push it 20 feet?
#5
OFFLINE
Posted September 15, 2016 - 03:48 PM
#6
OFFLINE
Posted September 15, 2016 - 05:06 PM
drove it.
- Gtractor said thank you
#7
OFFLINE
Posted September 15, 2016 - 05:07 PM
also going to change fluid whats the best way? looks like i have a plug in the hydro oil pan.
#8
ONLINE
Posted September 15, 2016 - 07:07 PM
That should have Red Type A automatic transmission fluid in it.That looks like that Traveler hydraulic oil from TSC.That stuff is way to thick.It's a 30 wt hydro oil.ATF Type A is much much thinner.
Page 11 This manual.It shows how to fill and check Both the Hydro and the Differential oils.
http://gardentractor...model-91725500/
If it's puking fluid then it's to full or to thick and can't burp the air out without pushing fluid out.
I filled mine up till it was between 1/4 and 1/2 way up the tube.Manual says if fluid is visible on the tube then the fluid level is good.There is not a fill mark on the tube.Just put it in till you can see it on the tube and your done.
If you fill it to full it won't have enough room for expansion and it will puke fluid out all over the place and possible blow out the 1" O ring between the oil sump and pump housing or the pan gasket.
Edited by EricFromPa, September 15, 2016 - 07:13 PM.
- MH81, Jazz and Xrperry have said thanks
#9
OFFLINE
Posted September 15, 2016 - 10:57 PM
what is the best way to get all the old fluid out
#10
OFFLINE
Posted September 18, 2016 - 08:44 AM
Edited by Xrperry, September 18, 2016 - 08:46 AM.
- KennyP said thank you
#11
OFFLINE
Posted September 25, 2016 - 01:09 AM
#12
OFFLINE
Posted September 25, 2016 - 06:48 AM
Something to look into would be an umbrella on the shaft, made out of old inner tube to help relocate the water.
