1968 variable speed 110 deck pulleys?
deck 110 1968 pulleys
12 replies to this topic
#1 rstern24 OFFLINE
rstern24
  • 5 posts
Posted September 15, 2016 - 01:04 PM
I recently receive a 1968 110 with an 8 hp Kholer. Everything seems to work fine but when the deck is engaged it is really noisy. I have tried to find pulleys for the deck on ebay and other sites. I was wondering if any one could point me in the right direction?
#2 DougT ONLINE
DougT
    Dog Approved
  • 7,085 Thanks
  • 5,063 posts
Posted September 15, 2016 - 01:23 PM
Welcome to the forum. The belt tensioner pulley should be fairly common. The spindles have replaceable bearings. The double sheave pulley was a little tougher. Not sure if Deere carries it or not. I was able to find a bearing for it and replace just the bearing.
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted September 15, 2016 - 01:45 PM
:welcometogttalk:
  • rstern24 said thank you
#4 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted September 15, 2016 - 02:13 PM
I have attached two diagrams from JDParts.  The second one MP569 shows the break down of the spindles which are rebuildable.  I suspect the noise is from spindle bearings #4 (x2) in the pics.  Deere part for the complete spindle is AM30302 and a quick search shows they are available on Amazon, Ebay, and other places.
#5 ford4wd08 OFFLINE
ford4wd08
  • 5 Thanks
  • 14 posts
Posted September 15, 2016 - 03:09 PM
I just went through my 39 deck not long ago. The double stack pulley is still available. I opted to buy a new spindle assembly (expensive I know) and plan on replacing the bearings on the one I replaced and keep as a spare. My is extremely quiet with new idlers and the like.
  • Trav1s and rstern24 have said thanks
#6 chieffan OFFLINE
  • 10,962 Thanks
  • 6,946 posts
Posted September 15, 2016 - 06:59 PM
Noise usually comes from bad bearings, not the pulleys.
#7 rstern24 OFFLINE
rstern24
  • 5 posts
Posted September 16, 2016 - 03:25 PM
Thanks for the quick replies. Has anyone had luck with getting the spindles apart to rebuild them? Should I replace the pulleys while I have it all apart? I added the only picture of the tractor I have at this time. It seems to be a nice tractor.
1968 John Deere 110
#8 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted September 16, 2016 - 03:27 PM
They are not hard to disassemble but not a pleasant experience.  It is easiest done with a press and lots of PB Blaster in my experience.
#9 ford4wd08 OFFLINE
ford4wd08
  • 5 Thanks
  • 14 posts
Posted September 16, 2016 - 03:33 PM
I have not attempted to take one apart yet since I don't have a press. As for the pulley, if there is nothing wrong with the pulley itself, just replace the bearing if you can. If I remember correctly the pulley bearing assembly was about 11 bucks from mother deere, so I opted to just replace the whole thing. The new replacements will require a bushing to ride on though.
#10 Trav1s ONLINE
Trav1s
  • 3,522 Thanks
  • 4,499 posts
Posted September 17, 2016 - 08:27 AM
When I rebuild the spindles on the 314 I owned for a while (the two outer spindles are the same as the three in your deck), I used the Deere part number to x-ref them and picked up replacements at the local Napa store.  IIRC they were about $7 per bearing.  Part number is JD9296 and a quick google search will yield cheaper options than "ford4wd08" offered.
Here is a Timken option:
http://cartneybearin...products/204rr6
#11 lyall OFFLINE
lyall
  • 2,180 Thanks
  • 1,577 posts
Posted September 17, 2016 - 05:57 PM
this is where I get my spindle bearings
$22 for 6 bearings free shipping
 http://www.ebay.com/...=STRK:MEBIDX:IT
$32 fro 12 bearings free shipping
http://www.ebay.com/...ZwAAOSwq5lToyRh
  • Trav1s said thank you
#12 rstern24 OFFLINE
rstern24
  • 5 posts
Posted September 17, 2016 - 09:39 PM
Thanks to all. I just ordered the bearings online so ill be tearing the spindles apart soon. Ill let you know how it goes.
#13 KEYBEAR OFFLINE
KEYBEAR
  • 7 Thanks
  • 23 posts
Posted September 18, 2016 - 03:25 PM
 For years people did this kind of work with zero nice tools just a hammer and punch .     It can be done just as well even without a press .    You can do it yourself no problem go slow and check the work as you go .
Also tagged with one or more of these keywords: deck, 110, 1968, pulleys
