Wanted
need parts Sears FF 20
parts
5 replies to this topic
#1 tilly 1999 OFFLINE
tilly 1999
  • 2 posts
Posted September 14, 2016 - 09:28 PM
any one know the part numbers or where to get parts for my sears FF20 garden tractor ? in need of axle seals for hydrostatic transmission
thanks to all
#2 KC9KAS ONLINE
KC9KAS
  • 5,443 Thanks
  • 4,710 posts
Posted September 15, 2016 - 04:22 AM
:welcometogttalk:
The seal can probably be found at a bearing/hydraulic shop. Try removing it without damaging it, there may be numbers on the seal.
I use a place called Tri State Bearing.
  • boyscout862 and tilly 1999 have said thanks
#3 KennyP ONLINE
  • 40,007 Thanks
  • 46,719 posts
Posted September 15, 2016 - 05:02 AM
:wave: Welcome to the forum. I have 2 of these. Nice machines. The axle seals are part # 788049 and are still available from Sears. The owners manual has the parts listing in it. Just be careful taking the hub off the axle, those are hard to find.
#4 tilly 1999 OFFLINE
tilly 1999
  • 2 posts
Posted September 15, 2016 - 06:59 AM
Morning all :thumbs:  What I have been told is I have a Eaton-11 hydrostatic transmission not a  Peerless trans axle that is a manual have looked in my book and if I did that right my seals are not available though sears. Am I wrong? I hope so like you said the 788049 is available but thats for the left side of a peerless the right is different?
thanks everyone
  my fav tractors is a cub cabet 123 with loader and a cub cabet 106  and my Big boy Sears FF20  ,2 JD 110 ,Allis wd wd45 and CA, And i know its not a tractor but they did make a three point hitch for some on them is My 1970 International scout ARISTOCRAT
Edited by tilly 1999, September 15, 2016 - 07:48 AM.
#5 KennyP ONLINE
  • 40,007 Thanks
  • 46,719 posts
Posted September 15, 2016 - 07:31 AM
That rear unit is an Eaton 11/ Peerless2500 combo. Both seals are the same, changed one set out on my FF20 a while back. The Ford LGT hydros use the same unit, just different axles (5 lug).
  • tilly 1999 said thank you
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted September 15, 2016 - 09:55 AM
:welcometogttalk: :wewantpics: of these machines, even the Scout!
Also tagged with one or more of these keywords: Wanted, parts
