Road Trip Rockwell Drill Press
7 replies to this topic
#1 Sawdust OFFLINE
Sawdust
  • 6798 Thanks
  • 3799 posts
Posted September 14, 2016 - 06:52 AM
I seen this older drill press on craigslist last night. We made arrangements to meet early. The ad says good shape & runs well. The badges don't look clear so I'm not sure what model it is. I should be back in a couple of hours hopefully with pics.
  • Gtractor said thank you
#2 boyscout862 OFFLINE
  • 15180 Thanks
  • 9996 posts
Posted September 14, 2016 - 07:14 AM
I hope that you have a safe trip. Good Luck, Rick
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted September 14, 2016 - 10:36 AM
Nothing beats a good drill press
  • Sawdust said thank you
#4 olcowhand OFFLINE
  • 44106 Thanks
  • 32302 posts
Posted September 14, 2016 - 10:55 AM
Those old Rockwell's are hard to beat!
#5 Sawdust OFFLINE
Sawdust
  • 6798 Thanks
  • 3799 posts
Posted September 14, 2016 - 03:19 PM
Well its mine & very happy with it. What I was expecting was a grease ball with a lot of rust & maybe worn...but just the total opposite. The PO had it for 2 years & very seldom used it. He said his PO took very good care of it & had not used it much either. It looks all original to maybe even the belt. It has some surface rust but nothing major. It runs good, solid, no vibrations or play in the spindle. One problem is the cracked & broken table where it mounts to the post. Before I went up there I went on line & found out a lot of these broke in that area. He didn't have the broken piece so I'll probably leave well enough alone for right now & shop for a replacement table later.
The model # 15-017 serial # 1603314. The motor brand is an Ajax 1/2HP. The chuck is a Jacobs 5/64"- 1/2". The PO was asking $100. I was willing to give him that until I seen the broken table mount. I offered him $70. & he countered $75. & I very happily agreed.
If you have any thoughts or history on these please give me your advice. I'm going to clean it up, & give it a good maintenance check. I also found some PDF manuals online I'll download for future reference. Thanks for looking.
Drill press1.jpg Drill press2.jpg Drill press3.jpg Drill press4.jpg Drill press5.jpg Drill press6.jpg Drill press7.jpg Drill press9.jpg
The big booger!
Edited by Sawdust, September 14, 2016 - 03:40 PM.
  • KennyP, MFDAC, boyscout862 and 1 other said thanks
#6 olcowhand OFFLINE
  • 44106 Thanks
  • 32302 posts
Posted September 14, 2016 - 04:04 PM
Awesome deal and in awesome condition!  I'd get me a piece of 1/4" x 2" strap & weld with nickel or stainless rod to repair that clamp.  Just spot weld so it doesn't heat things too hot to create cold cracking.  Once cooled from that, then add more spot welds.
#7 MFDAC OFFLINE
MFDAC
  • 3708 Thanks
  • 1771 posts
Posted September 14, 2016 - 07:57 PM
Great deal on a great tool, Jim!
DAC
#8 Sawdust OFFLINE
Sawdust
  • 6798 Thanks
  • 3799 posts
Posted September 19, 2016 - 03:25 PM
I had some time this morning to do some cleaning. I took some small parts off & wire brushed them, they cleaned up quickly. I raised the head up about 6". Before I could do that I had to clean the mast up where it had some surface rust inside the head area. I need to use this now so I'll probably wait later to do a better job of cleaning & painting. This is a very nice machine well built, runs smooth & no wobble. I got a friend that should be able to weld up the broken table. I've never welded cast before. I priced some tables on eBay & they cost as much as I paid for the DP :mad2:
Don't worry about all the wires hanging in the back their not hot.  These are some circuits I ran for my new box I'll be installing this winter.
Edited by Sawdust, September 19, 2016 - 03:28 PM.
  • olcowhand said thank you
