Mower belt gets loose when PTO engages drive belt
john deere 175 mower deck belt slippage
4 replies to this topic
#1 Hrguy OFFLINE
Hrguy
  • 4 posts
Posted September 13, 2016 - 08:21 PM
My mower deck belt is tight as Dick's hatband until I engage the PTO.  Then the main pulley is pulled toward the front of tractor just enough for my mower belt to slack and blades turn slowly.  How can I stabilize the double pulley?  This is a 38" deck (two blades) on John Deere 175. (the original 175)
Thanks
#2 secondtry OFFLINE
secondtry
  • 2,109 Thanks
  • 1,508 posts
Posted September 13, 2016 - 08:37 PM
 Maybe pictures would help. I for one have no idea which is the main pulley. I have no idea how a pulley could move in any direction without other things going with it. Is the pulley on the deck. If so is the deck moving with it. More information is needed. Often the search for more information finds the problem. Don
#3 chieffan ONLINE
  • 10,953 Thanks
  • 6,944 posts
Posted September 13, 2016 - 08:45 PM
Sounds like worn lift linkage allowing the whole deck to move around.
  • Gtractor and Hrguy have said thanks
#4 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,279 Thanks
  • 4,513 posts
Posted September 13, 2016 - 09:58 PM
Then the main pulley is pulled toward the front of tractor.
I would check the mounts on the main pulley..
  • Hrguy said thank you
#5 Hrguy OFFLINE
Hrguy
  • 4 posts
Posted September 20, 2016 - 01:03 PM
Chieffan, you may be right because the deck does move a little forward.  Now to figure out how to adjust lift linkage...
