Sears suburban solid state
5 replies to this topic
#1 otrick OFFLINE
otrick
  • 4 Thanks
  • 4 posts
Posted September 13, 2016 - 08:54 AM
Im interchanging solid states on a sears suburban super 12 and im wondering if theres any gap or certain position the solid state has to put on?
Thanks
#2 boyscout862 ONLINE
  • 15195 Thanks
  • 10000 posts
Posted September 13, 2016 - 10:57 AM
Be very carefull. Those old Tecumseh solid state ignitions can be touchy and they are very expensive to replace. Download the manual from our Manuals Section and proceed very carefully. Good Luck, Rick
#3 Tecumseh power OFFLINE
Tecumseh power
  • 1535 Thanks
  • 1133 posts
Posted September 13, 2016 - 11:53 AM
Thanks
.006-.010"
#4 Tecumseh power OFFLINE
Tecumseh power
  • 1535 Thanks
  • 1133 posts
Posted September 13, 2016 - 11:56 AM
Why are you changing it ? Did you lose spark? Pull the flywheel and take the stator off if you still have problems. Check the wire that goes from the stator to the solid state. They often break in the jacket and or get a bare spot and lose spark. Repair the wire under the bad spot if this is the case. Check it with a volt meter for continuity. While wiggling it around. I would say 80% of them develop this problem and it's an easy fix
#5 nkaust OFFLINE
nkaust
    Deere Hunter
  • 294 Thanks
  • 269 posts
Posted September 13, 2016 - 08:13 PM
if the ssi is bad let me know i got an extra for a good price
#6 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2784 Thanks
  • 1366 posts
Posted September 13, 2016 - 09:58 PM
Sears solid state ignition replacement This is one of two companies making new replacements.
  • jimmy G said thank you
