Bolens G152 pick up
7 replies to this topic
#1 case442 OFFLINE
case442
  • 723 Thanks
  • 438 posts
Posted September 12, 2016 - 07:46 PM
Hi All,
I picked up this Bolens G152 today. Only 2 minutes from my house. P.O. Was working on the track vac and the tractor rolled done a hill. It stopped but unfortunately a face plant was in order. Came with a second (original) deck, front / mid pto set up (original) the rear pto driven track Vac head, and a lawn cart. The front needs pulled. Radiator is still full. Exhaust manifold cracked off at the muffler. I'll pull it and see if I can get it started. Here's the pictures. Any suggestions on parts, let me know.
Thanks
Mike
  • Gtractor, Traill95 and boyscout862 have said thanks
#2 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted September 12, 2016 - 09:23 PM
Ouch. Looks like it was a decent machine prior to it'so incedent. I should be able to assist with some new parts if needed, but the sheet metal you'll probably have to straighten up what you've got or find some from a salvage tractor.
Edited by ClassicBolens, September 12, 2016 - 09:23 PM.
#3 case442 OFFLINE
case442
  • 723 Thanks
  • 438 posts
Posted September 12, 2016 - 09:42 PM
Thank you,
I will contact you once I have assessed the damage. Any idea on the model year from the serial number?
Thanks, Mike
#4 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted September 12, 2016 - 10:20 PM
1982-1991, based on the 3 cylinder engine and the hood stripes. I do not know of a serial # by year list.
Which engine does it have? Early models were Mitsubishi, later models were Isuzu.
Edited by Cat385B, September 12, 2016 - 10:26 PM.
  • ClassicBolens said thank you
#5 case442 OFFLINE
case442
  • 723 Thanks
  • 438 posts
Posted September 12, 2016 - 10:51 PM
It's a Mitsubishi
#6 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted September 12, 2016 - 10:55 PM
Ditto on the 1982-1991 build. Very little changed throughout these years. Unfortunately, no reliable information is available to pin it to the exact year.
I can assure you, all of the engines in these 15 and 17 HP tractors were Mitsubishi built. Models K3A 15HP and K3B 17HP. Isuzu engines were only used in the larger 19, 24, 21, 27 and 29 HP tractors. The engine information was misprinted in some of the dealer seminar books.
  • Cat385B said thank you
#7 Username OFFLINE
Username
  • 2090 Thanks
  • 1435 posts
Posted September 13, 2016 - 09:30 AM
I seen that for sale and managed holding myself back from going after it at the price it was listed at.Hope you get it up and running with little trouble.
#8 case442 OFFLINE
case442
  • 723 Thanks
  • 438 posts
Posted September 13, 2016 - 09:52 AM
I was quick on that one John. He said I was the first to call and by the time I got there he had numerous calls already.
