The collection keeps growing!
28 replies to this topic
#16 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted September 15, 2016 - 04:51 PM
Here's a better pic of the carb. It has the 4 plugs but they're not square. So if this is a 4 ball carb the probability of it being an early one are pretty good?
#17 DougT OFFLINE
DougT
    Dog Approved
  • 7,118 Thanks
  • 5,081 posts
Posted September 15, 2016 - 05:06 PM
That's the 4 ball carb. Maybe my feeble mind was wrong on the square plugs. If it wasn't the early tractor, you've got a good start on the makings of one. Check the spare flywheel real close around the hub for cracks. If it's good, we only need to come up with one other.
  • Nato77 said thank you
#18 Rustysteele OFFLINE
Rustysteele
  • 300 Thanks
  • 92 posts
Posted September 16, 2016 - 05:49 PM
You might want to switch the handles around on the Beeman, I`ve had a few over the years, and the handles always point down at the operator end. Nice finds!
#19 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted September 16, 2016 - 10:55 PM
The plan is to make them longer like they're suppose to be and switch the handles too. They're really ackward the way they are now.
#20 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted December 04, 2016 - 08:37 PM
Went for another drive yesterday and picked myself up another Beeman.this ones a little newer than the last one. The bad thing is it's stuck in gear. Have to find the thread that talked about that.
  • Gtractor, Mike Unwin and jimmy G have said thanks
#21 DougT OFFLINE
DougT
    Dog Approved
  • 7,118 Thanks
  • 5,081 posts
Posted December 04, 2016 - 08:49 PM
That is a nice looking tractor. Does it have a serial number?  Here is the thread that I tried to explain the clutch.  http://gardentractor...1920-beeman/?hl= beeman
#22 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted December 04, 2016 - 09:18 PM
#G206039 So it should be a 1920 right?
#23 DougT OFFLINE
DougT
    Dog Approved
  • 7,118 Thanks
  • 5,081 posts
Posted December 04, 2016 - 09:52 PM
Most likely but sometimes I question myself on that. Seems there are a lot of G20 numbers and I don't remember any G21 or G22s. Near as I can tell, Beeman tractor Co was only 20-22 and was reorganized as New Beeman in 23. Whether they made them all in 20 and spent the next 2 yrs selling them or just called them all 20s is anybody's guess.
#24 DougT OFFLINE
DougT
    Dog Approved
  • 7,118 Thanks
  • 5,081 posts
Posted December 04, 2016 - 09:53 PM
That style aircleaner wasn't used in 20 but it could have been changed too.
#25 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted December 04, 2016 - 10:24 PM
Is there any place a guy could take a hard chunk of wood and a hammer to do some taping to loosen (possibly) the clutch so it would roll? Or does a guy have to take the bottom cover off and be done with it?
#26 DougT OFFLINE
DougT
    Dog Approved
  • 7,118 Thanks
  • 5,081 posts
Posted December 05, 2016 - 12:36 AM
I wouldn't say they roll even with the clutch released. At least not very easy. If you pull the handle all the way back and crank it, does it try to pull itself? You can try to see if you can get any more adj out of the rod. The other option is to take the small plate off under the piston and see if you can pry the big gear away from the stationary side taper. If it's stuck somewhere else, it won't work although a good dose of penetrant might help.
#27 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted December 05, 2016 - 08:14 PM
The only way to make it roll is crank the engine over. The right side (standing behind it) freewheels all the time and the left is in gauged. I did tighten the linkage up some but didn't help. Sounds like I'll have to take the cover off.
#28 DougT OFFLINE
DougT
    Dog Approved
  • 7,118 Thanks
  • 5,081 posts
Posted December 05, 2016 - 08:25 PM
Sounds like getting the big gear to move to the right might cure it. Until the next time.........
#29 Rustysteele OFFLINE
Rustysteele
  • 300 Thanks
  • 92 posts
Posted December 17, 2016 - 08:57 AM
I`ve had a couple Beemans in the past, and the clutches always stuck if they were left engaged. I would put a block of wood in front of the wheels to prevent it from moving, unhooked the spark plug, engage the clutch, and crank it over, they would always pop free for me. I remember early on I had one at a show, and started it up. The clutch had stuck overnight, and it took off as soon as it started! Luckily I had enough room to maneuver it into an open area where I could reach around and kill the mag. This is a good thing to remember to check before you start it, make sure the clutch isn`t stuck! I don`t remember how well they roll with the clutch disengaged, but I doubt it`s very easily.
