Trailer hitch for the R/T tractor
12 replies to this topic
#1 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,197 Thanks
  • 1,917 posts
Posted May 24, 2011 - 01:43 PM
I used the Rock Rake on the 3-point to smooth out some areas in the drive way the other day ( sorry, I didn't take any photos ).
Now I need to get the roller out and pack the gravel back down but there isn't a hitch on the back of the tractor.
So I decided to make up one of those hitches that mount on the 3-point.
The crossbar is made out of 2 inch angle iron with 5/8 diameter pins welded on each end.
A 1/4 x 2 inch flat bar is welded on top for the hitch ball to mount on.
The upright support bar is made out of a piece of 1-3/4 inch square tube.
Here's the finished hitch mounted on the 3-point.
The back side of the angle iron cross bar has a piece of flat steel welded to it to form a triangular shape for strength.
There is a half round notch machined out of the bottom of the upright support to allow any water to drain out.
The hitch allows good clearance for making sharp turns.
The roller is getting filled and then I can run it over the drive.
#2 NUTNDUN OFFLINE
  • 10,352 Thanks
Posted May 24, 2011 - 02:07 PM
The hitch turned out great and I am still in love with that tractor :D
That is a really nice sized roller you have. Can you tell a big difference in the ground after using it?
  • jdcrawler said thank you
#3 Ron White OFFLINE
Ron White
  • 124 Thanks
  • 124 posts
Posted May 24, 2011 - 02:23 PM
That is one sweet tractor !!
#4 mjodrey OFFLINE
Posted May 24, 2011 - 02:29 PM
That's a good looking hitch ,Ray.:thumbs:
#5 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,197 Thanks
  • 1,917 posts
Posted May 24, 2011 - 03:20 PM
I built that roller about 25 years ago.
I think it holds around 80 gallons so that would be somewhere around 560 pounds when full.
It does a good job of packing things down.
#6 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted May 24, 2011 - 04:26 PM
Great looking hitch, but did you have to use such a bright shade of yellow lol. Great work on it all as always, that yellow will fade in time. :D
#7 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted May 24, 2011 - 05:28 PM
Thank God he didn't put green pinstripes on it.:bigrofl::bigrofl:
#8 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1,805 posts
Posted May 24, 2011 - 05:51 PM
Nice looking ball hitch Ray, and I'm always impressed with the thought that goes into your builds, the cut out to drain water, I'd not have thought of that until after the fact.....
Thanks for showing us another R/T tractor project.
Peter
#9 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted May 24, 2011 - 06:33 PM
Ray. all joking aside, you do excellent work. But why yellow? Is that so you can find where you put it? Or do you just have a large quantity of that color?
#10 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,197 Thanks
  • 1,917 posts
Posted May 25, 2011 - 06:37 AM
why yellow?
Originally, I had intended to paint it the same gray as the tractor but there wasn't any paint left and I wasn't going to drive 25 miles to town for just a can of paint.
The only cans that felt like they had enough paint in them were red, blue & yellow.
Last year I built this cart So Marie could ride with me when I'm driving the Ridemaster around at the tractor shows.
It was painted yellow because I had a lot left over from painting the Ridemaster wheels.
With this 3-point hitch, I can also tow the cart behind the R/T so I painted the hitch yellow to match the cart.
I kind of like the color and I'm thinking of painting the back blade and rock rake yellow also.
Edited by jdcrawler, May 25, 2011 - 07:35 AM.
#11 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted May 25, 2011 - 07:10 AM
That explains it all. The ladies like color matching things.
#12 murphy OFFLINE
murphy
  • 3 Thanks
  • 44 posts
Posted May 29, 2011 - 03:20 AM
It has been a couple of months since lurking around here. When I see a post from jdcrawler, I have to see what he is up to. As always, it is good stuff.
Ray, have you ever weighed R/T?
#13 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,197 Thanks
  • 1,917 posts
Posted May 29, 2011 - 08:45 AM
Murphy
I haven't been around a scale to get a weight on the tractor.
I figure it weighs somewhere around 1500 pounds ( or more )
I know for as small as it is, it's a doggone heavy tractor.
