P218 help
5 replies to this topic
#1 glen OFFLINE
glen
  • 3 posts
Posted May 24, 2011 - 10:02 AM
HELLO,
I AM NEW TO THIS FORUM.
I HAVE A JD 318 WITH A P218 IN IT. IT WAS SMOKING AND BLOWING OIL INTO THE BREATHER WHEN I PARKED IT A COUPLE OF YEARS AGO. I AM LOOKING FOR HELP IN FINDING MOTOR PARTS FOR AN OVER HAUL. CAN I FIND PARTS? CAN I FIND ANOTHER MOTOR? WHAT IS THE WAY TO GO?
ANY HELP WOULD BE GREAT! THANKS!!! :rocker2:
#2 mjodrey OFFLINE
Posted May 24, 2011 - 10:15 AM
glen,:welcometogttalk:
Glad to have you with us.
  • glen said thank you
#3 glen OFFLINE
glen
  • 3 posts
Posted May 24, 2011 - 10:18 AM
Thank you!!
#4 NUTNDUN OFFLINE
  • 10,352 Thanks
Posted May 24, 2011 - 10:19 AM
First welcome to GTtalk, second you might want to turn the caps lock off. Some people view that as shouting.
There are several places to get Onan parts from. A lot of guys use Onanparts.com. Are you sure you are in need of a rebuild? Might just be a clogged crankcase breather causing most of your issue.
You can find another motor, problem is if it isn't close by for a local pickup then shipping is expensive. Where are you located? I think you would be better off rebuilding the one you have if that is the path you need to take. They have full piston kits available. The P series Onans are good engines. I have a P220 and at first I didn't care for it but now that I have the bugs worked out of it I really like it.
#5 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted May 24, 2011 - 01:01 PM
A faulty oil dipstick seal can cause oil out the breather into the intake also. I use www.onanparts.com
With the crankcase breather blowing oil, the smoke may only be from this oil & not worn rings/valve guides.
#6 glen OFFLINE
glen
  • 3 posts
Thanks for the info. George. Yes I have checked the crankcase breather. I just attempted to get on the map and the registry. I am trying to fix the 318 so I can get rid of my JD 855. It doesn't have a loader and I would like to get a 35 to 40hp tractor with a loader for around my farm. I have a backhoe but it is to big to get into the barn to clean out stalls.
Thanks again. Glen
