782 KT17 Series 1 to Series 2 engine swap
9 replies to this topic
#1 Schwarzkopf9 OFFLINE
Schwarzkopf9
  • 51 Thanks
  • 49 posts
Posted September 08, 2016 - 04:26 PM
Hey guys, I just got my grandpas old 79 or 80 (?) 782 recently. After finally getting it running after sitting for a while (7 years), I am unimpressed with the engine. It has a rather loud knock and spews smoke. So, its a rebuild. My question is, would it be worth the rebuild of the series one that is on it, or would it be worth the time/money to repower it with a series 2? There is a series 2 for sale near me that may need a rebuild and came out of a John Deer - he wants 400$ for it. Runs but doesn't run pretty. Does anyone know how/if it would swap over to my 782? Hoping for plug and play install but, I don't really know. Thanks!!
#2 KennyP ONLINE
  • 41,453 Thanks
  • 47,382 posts
Posted September 08, 2016 - 04:50 PM
:wave: Welcome to the forum! That should be a plug and play swap. What is the series 2 doing?
#3 Schwarzkopf9 OFFLINE
Schwarzkopf9
  • 51 Thanks
  • 49 posts
Posted September 08, 2016 - 05:40 PM
says wont hold rpm. Carburetor? Vac leak perhaps? hard to tell...heres the link;
http://stcloud.craig...5754673564.html
#4 KennyP ONLINE
  • 41,453 Thanks
  • 47,382 posts
Posted September 08, 2016 - 05:56 PM
That could be several things. I'm sure someone here can help you more than I can!
#5 aagitch OFFLINE
aagitch
  • 107 Thanks
  • 83 posts
Posted September 08, 2016 - 07:02 PM
The JD kohler would need the same shaft diameter and lenght for it to be a simple engine swap.
#6 Schwarzkopf9 OFFLINE
Schwarzkopf9
  • 51 Thanks
  • 49 posts
Posted September 08, 2016 - 07:25 PM
you mean the hydro driveshaft? or pto side?
#7 aagitch OFFLINE
aagitch
  • 107 Thanks
  • 83 posts
Posted September 09, 2016 - 01:42 AM
Pto side
#8 olds45512 ONLINE
olds45512
  • 1,498 Thanks
  • 739 posts
Posted September 09, 2016 - 08:35 AM
Won't hold rpm could be the governor, if so the engine will need to come completely apart. I wouldnt pay that much for an engine with an unknown problem.
#9 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted September 09, 2016 - 02:14 PM
You got that right
#10 Schwarzkopf9 OFFLINE
Schwarzkopf9
  • 51 Thanks
  • 49 posts
Posted September 09, 2016 - 05:47 PM
I agree with you there. I'm thinking Ill tear the engine I have apart and see what needs fixing, then Ill make a decision. Rebuild kits don't look that expensive for this this motor....
