Wood pushin, try that with a new garden tractor !
9 replies to this topic
#1 propane1 OFFLINE
propane1
  • 9,451 Thanks
  • 4,389 posts
Posted September 08, 2016 - 01:05 PM
So, the mf14 pulls the logs down off the top of the pile, logs then go onto the saw bench, run by the ferguson, then the blocked wood goes to the spliter, run by the ferguson and held in place by lgt100, once split, a pile is made beside the spliter and the mf14 pushes the pile away.
And the MF is only just above idle. No reving up the engine required.
Your comments,
Noel
  • Gtractor, MH81, Bruce Dorsi and 8 others have said thanks
#2 dthomp17 OFFLINE
dthomp17
  • 605 Thanks
  • 482 posts
Posted September 08, 2016 - 01:19 PM
Sounds like you've got a system that works and enough older GT to do it.  Can't have too many GT's.
  • KennyP, boyscout862, oldedeeres and 2 others have said thanks
#3 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted September 08, 2016 - 01:41 PM
Nice set up and so fun to work with.  If you're going to do work like this, it's always better to add a fun factor in.  I do wish I had a pile of wood like that!
  • KennyP, dthomp17, boyscout862 and 2 others have said thanks
#4 KennyP OFFLINE
  • 40,899 Thanks
  • 47,099 posts
Posted September 08, 2016 - 01:52 PM
Now that's putting them to work!
  • dthomp17, propane1 and chieffan have said thanks
#5 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,796 Thanks
  • 5,094 posts
Posted September 08, 2016 - 02:52 PM
Great setup!
Although I really appreciate my $.87/gal propane after seeing all that work. :beer:
#6 chieffan OFFLINE
  • 11,346 Thanks
  • 7,106 posts
Posted September 08, 2016 - 03:12 PM
Now all you need is a pallet building to put the split wood in to keep the rain and snow off it.  Pallets let the air flow through and help dry out any wood that is not dry yet.  I don't burn green wood.  Nice setup.  Going to go look at a couple trees this evening now that they mowed the CRP/weeds down.
  • Gtractor, oldedeeres and propane1 have said thanks
#7 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted September 08, 2016 - 03:23 PM
Or you could build something like this.  This works great for me and it wasn't real expensive to build.
  • Gtractor, MH81, KennyP and 4 others have said thanks
#8 MH81 OFFLINE
  • 29,978 Thanks
Posted September 08, 2016 - 07:42 PM
Great system. Is that a Dearborn or a Ferguson buzz saw?
#9 propane1 OFFLINE
propane1
  • 9,451 Thanks
  • 4,389 posts
Posted September 08, 2016 - 07:50 PM
I don't believe its either. Name starts with a B. Can't remember what it is. Befco, maybe. It's a great saw. Blade all covered up. I like that.
Noel.
Edited by propane1, September 09, 2016 - 04:28 AM.
  • backwoods said thank you
#10 oldedeeres OFFLINE
oldedeeres
  • 10,483 Thanks
  • 5,093 posts
Posted September 09, 2016 - 09:01 AM
Using the resources at hand, I like that. A job for everyone and everyone doing the job.....they all look happy.
  • propane1 said thank you
