Toro 322D Pivot Shaft issues
9 replies to this topic
#1 KennyP ONLINE
  • 52540 Thanks
  • 53104 posts
Posted September 08, 2016 - 10:51 AM
I have been trying to figure out why the PTO u-joint near the tractor was rubbing the frame since I got this thing. I finally found the problem. The PTO pivot bushings are toast. Luckily they are a 1" OD X 3/4" ID flanged bushing bushing and easily found. Here's some pics for you guys.
This is where it has been beating the daylights out of the frame when I used the float setting for the deck.
And a little later, I had the shaft out and could see where the issue is.
That makes me happy as a new PTO Pivot assembly is nearly $300!
  • olcowhand, Gtractor and boyscout862 have said thanks
#2 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 10226 Thanks
  • 5243 posts
Posted September 08, 2016 - 11:18 AM
I bet that sounded good!  :(
#3 jms180 OFFLINE
jms180
  • 2637 Thanks
  • 2152 posts
Posted September 08, 2016 - 12:43 PM
good work Kenney finding the problem and the solution to the problem. Thank for the pictures
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted September 08, 2016 - 01:09 PM
Slight vibration
#5 KennyP ONLINE
  • 52540 Thanks
  • 53104 posts
Posted September 08, 2016 - 01:50 PM
Slight vibration
That's what you felt when the deck went down into a low area. Been doing it for some time, just couldn't figure it out. I was looking at it again as I had put one new bolt in and it was smacking it real hard. Leaned in to look at the pivot mechanism and leaned on the handle. It moved back wards a ways and I saw all the wear in the bushings. The shafts have some wear, but I think it will be okay.
I took this pic so I would have a reference for how this shaft is set up. And the second one is of the three worst bushings. One looks like a replacement, but not flanged.
Now I'm waiting for funds to fix it.
  • Gtractor and stiemmy have said thanks
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted September 08, 2016 - 02:28 PM
Kind of wallered out
#7 stiemmy OFFLINE
stiemmy
  • 2541 Thanks
  • 1830 posts
Posted September 08, 2016 - 07:54 PM
Yep, that would do it!
Couple bucks at any Ace Hardware, or Farm/Auto store, and back in business!
Edited by stiemmy, September 09, 2016 - 02:38 PM.
#8 KennyP ONLINE
  • 52540 Thanks
  • 53104 posts
Posted September 14, 2016 - 06:09 PM
Got the bushings today and after 4 attempts, got the shaft back in place. So far so good!
#9 olcowhand OFFLINE
  • 44106 Thanks
  • 32302 posts
Posted September 14, 2016 - 06:55 PM
Must have been a little loud when it was hitting!  Glad it was cheap & easy to repair!  :dancingbanana:
#10 KennyP ONLINE
  • 52540 Thanks
  • 53104 posts
Posted September 16, 2016 - 05:14 PM
Yes it was loud! Been doing it for a while, eating a little at a time. Just took a bit to figure out what was wrong.
  • olcowhand said thank you
