Points setting on Kohler 321s
5 replies to this topic
#1 SNUFFY OFFLINE
SNUFFY
  • 188 Thanks
  • 272 posts
Posted September 08, 2016 - 08:10 AM
Fixin to see if this thing will run....can`t find gap setting on points in any of the numerous manuals I access. I`m guessin .012-015 ???. I also could use a good pic of the carb side to see how the throttle and choke cables hook up.....and check the governor and springs. It was all junk when I got it.
Almost forgot...`74 PK 2414...
Edited by SNUFFY, September 08, 2016 - 08:14 AM.
#2 boyscout862 ONLINE
  • 15182 Thanks
  • 9997 posts
Posted September 08, 2016 - 09:20 AM
Download the Kohler engine manual from our Manuals Section. The gao is in there but as you point out it is kinda hidden. I think the gap is 0.020" but there is a timing issue to address too. Good Luck, Rick
This is the one that you want: http://gardentractor...service-manual/ page 8.2
Edited by boyscout862, September 08, 2016 - 09:29 AM.
#3 SNUFFY OFFLINE
SNUFFY
  • 188 Thanks
  • 272 posts
Posted September 08, 2016 - 10:51 AM
Thanks Boyscout.....a much better manual than the ones I`ve been looking at from kohler
#4 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 17913 Thanks
  • 7668 posts
Posted September 08, 2016 - 10:53 AM
0.020" is the correct initial set-point and should be good enough to get the thing running..
#5 lyall OFFLINE
lyall
  • 2459 Thanks
  • 1722 posts
Posted September 08, 2016 - 08:24 PM
also check the spark plug gap
set at .025
#6 MNGB OFFLINE
MNGB
  • 5322 Thanks
  • 2588 posts
Posted September 08, 2016 - 09:37 PM
Spark plug gap on the K321 is 0.035"  not 0.025"
