Whats the most youve towed?
20 replies to this topic
#1 DZG OFFLINE
DZG
  • 607 Thanks
  • 525 posts
Posted September 06, 2016 - 06:23 AM
Or drug, or otherwise used your tractor to move?
It wasnt mine, but my buddy once pulled my 83 F150 (loaded to the gills with dirt) up a pretty steep hill (yes unsafe i know, but we were dumb 17 year olds), on his street with a 79 Sears GT 19.9 with a 19.9hp onan and 3sp trans with a range selector, it made it halfway up the broke traction....
Whats your stories? Or pics?
#2 toppop52 ONLINE
toppop52
  • 5,010 Thanks
  • 4,627 posts
Posted September 06, 2016 - 10:26 AM
I pulled my Donzi Z25 with big block Chevys, boat and trailer with fuel weighed about 6500 lbs, with my old 6 h.p. Pennsylvania Panzer, only across the yard and I had my hitch rigged with a dolly under it. It moved it just fine in the low gear pulley.
#3 olds45512 OFFLINE
olds45512
  • 1,338 Thanks
  • 677 posts
Posted September 06, 2016 - 12:21 PM
Probably not the most weight I've pulled but a pretty funny story. My neighbor's tractor wouldn't run so I decided to tow it to my house with my cub 108, I had her get on it and told her to put it in neutral. I got about halfway to my house before I turned around to look and the rear tires on her tractor were locked up and I was just dragging it at wot in 3rd gear like it wasn't back there, the tractor with her on it was probably 600lbs or more but the old cub didn't mind at all.
  • LilysDad and Sawdust have said thanks
#4 twostep OFFLINE
twostep
    Rockstar
  • 1,969 Thanks
  • 2,528 posts
Posted September 06, 2016 - 02:39 PM
I jockey my 16' jeep trailer around with my kubota. The only issue I have is keeping the front end down for steering, thank goodness for cutting brakes.
#5 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,966 Thanks
  • 9,612 posts
Posted September 06, 2016 - 03:27 PM
It wasn't mine, but at the tollway garage they hooked up a Gravely L to an Oshkosh snowplow to see if it would move it. Yup it did!
  • backwoods said thank you
#6 dropped82 ONLINE
dropped82
    Nut Case
  • 2,447 Thanks
  • 1,792 posts
Posted September 06, 2016 - 08:30 PM
I skidded logs approximately 7' long out of a wooded area with my Massey 16. Kept hanging more weight on the front so I could steer. Never stopped the tractor though.
While back, used a 74 Deere 112 with a 12 kohler to pull my 1/2 ton extended cab chevy to the street. Never had an issue. Friend on mine who was r/r the tranny in it wanted to buy it that evening haha.
I know of some other times that I probably shouldn't share. One of those "good idea at the time" moments.
Eric
Edited by dropped82, September 06, 2016 - 08:32 PM.
#7 twostep OFFLINE
twostep
    Rockstar
  • 1,969 Thanks
  • 2,528 posts
Posted September 07, 2016 - 08:14 AM
No doubt that traction and steering are the limiting factors for our GT's. Power is rarely every the problem!
#8 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,101 Thanks
  • 4,880 posts
Posted September 07, 2016 - 08:35 AM
I pulled an 8 wheeled, 53 foot van trailer with a road tractor.  Had just over 40,000 pounds in the trailer plus the weight of the trailer.
:anvil_drop:
#9 DZG OFFLINE
DZG
  • 607 Thanks
  • 525 posts
Posted September 07, 2016 - 09:59 AM
:anvil_drop:
Hey i do that to!....only closer to 54k in a big shiny milk wagon :p
  • Gtractor said thank you
#10 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted September 07, 2016 - 11:54 AM
34' diesel pusher motor home with my S24
#11 MH81 OFFLINE
Posted September 07, 2016 - 02:32 PM
:anvil_drop:
Pulled it with WHAT?
#12 DZG OFFLINE
DZG
  • 607 Thanks
  • 525 posts
Posted September 07, 2016 - 03:30 PM
Road tractor=semi truck :)
#13 MH81 OFFLINE
Posted September 07, 2016 - 03:38 PM
Oh, the way I read that,nit meant the trailer and truck were hooked together and he drug ALL THAT with something
#14 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,101 Thanks
  • 4,880 posts
Posted September 07, 2016 - 03:39 PM
379 Peterbilt long nose conventional with a 3408b Cat and a 13 speed Fuller Road Ranger with 60 inch flat top sittin on 24.5 Alcoa aluminum Budds.
#15 MH81 OFFLINE
See post just above yours
