Angle Frame Ford tiller help needed
9 replies to this topic
#1 Dayton_King OFFLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted September 05, 2016 - 11:28 AM
I am trying to hook up the Ford tiller to the White 112H. I have it mounted but the tiller can travel left to right about 2 inches. It almost seems like it should fit my Ford T-800 better. How do I mount this tiller to the White
#2 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted September 05, 2016 - 01:25 PM
Cant remember 100% as I sold my tiller about 2 years ago, but IF my memory serves me correctly, I believe there were bushings on those pins to get the tiller pulley to align with the pulley on the tractor.
Also need the double groove trans pulley to run the tiller.
I think there are manuals posted on this site about that tiller. Id look at the Jakes section if needed. Cheers;)
  • KennyP and Dayton_King have said thanks
#3 Dayton_King OFFLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted September 05, 2016 - 03:11 PM
I have a double pulley. Installed that this morning
#4 Dayton_King OFFLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
If there are bushings can some one get me the measurements
#5 Dayton_King OFFLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted September 05, 2016 - 04:33 PM
It's a direct fit for the Ford T-800
#6 Dayton_King OFFLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted September 05, 2016 - 04:40 PM
#7 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted September 05, 2016 - 04:41 PM
Measure the pin diameter for correct bushing hole size, and measure the gap between tiller and frame for length.
#8 KennyP OFFLINE
  • 40,110 Thanks
  • 46,756 posts
Posted September 05, 2016 - 05:43 PM
You need those bushings! Pin's are .75 OD. Gotta use something to measure how long they need to be!
#9 MM MARK OFFLINE
MM MARK
  • 82 Thanks
  • 38 posts
Posted September 05, 2016 - 08:06 PM
Are you going to use this or are you just showing it?  If you are using it you will bend the pins with bushings installed to take up gap, showing it this way is ok. There is another A frame mount for the later tractors, pipes are as wide as the frame it also has a different engagement lever so it will not hit the seat pan.
  • HALFSCALE and Dayton_King have said thanks
#10 Dayton_King OFFLINE
Dayton_King
  • 1,456 Thanks
  • 1,143 posts
Posted September 05, 2016 - 09:16 PM
I want the later model a frame to use. I can use the tiller now on my T-800 but I was told it a hard on the high low if i hit something
Edited by Dayton_King, September 05, 2016 - 09:20 PM.
