Got a Little Green on it
1st john deere
83 replies to this topic
#1 oldcuz OFFLINE
oldcuz
  • 68 Thanks
  • 107 posts
Posted September 04, 2016 - 08:10 PM
Just got my 1st John Deere 210 today its a project but unlike my other one a
Sears SS/16 its not been living outside in the weather for years engines not
seized and full of water nor is the transaxle, the brakes and parking brakes even
still work has a working deck still on the tractor its probably 90% complete a
few little parts missing and yes I know all those little parts add up
It has a new used K241 Kohler engine the original engine blew up suppose to run
ok the man I bought it from is pretty honest would not even let me pay for it
till I got the engine running, he wanted it out of his garage it had been In
there for a few years, his cousin started working on it about a year ago and put
the used engine on it but unfortunately he has passed away and never got to
finish it.
I was looking threw the manual section and found one for a 110 but no 210 looks
like something is not right where the engine cradle bolts to the frame engine was
dropped down in the rear I have it rigged up so its sitting level would not want
to try and start it like that might even be something missing that bolts to the
cradle I am sure a lot of stuff got misplaced or threw away over the years, here
are a few photos of my little green tractor
  • Gtractor, grnspot110, Alc and 5 others have said thanks
#2 Merle013 OFFLINE
Merle013
    If I can't do it slow then it's not going to get done.
  • 274 Thanks
  • 188 posts
Posted September 04, 2016 - 10:12 PM
Good looking tractor. I see what you mean about the engine. The muffler looks real close to the hood.
  • oldcuz said thank you
#3 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted September 05, 2016 - 12:49 AM
Rubber Isolators on the mount plate in or on wrong side of the metals?  You would think they would go in one way, but later find they did a diff way. I found that on a Bolens I was working on. OR, those Isolators can be bought in diff thicknesses, maybe bought wrong sized ones for one one end? Would think the metal mount plate would not change, and only changeable at those mount Isolators, so think take a look there.
#4 Enginerod OFFLINE
Enginerod
  • 245 Thanks
  • 294 posts
Posted September 05, 2016 - 07:03 AM
I had a 216, the ears on the rear of the engine cradle sat directly over the isolators. Maybe wrong cradle?
  • Trav1s, boyscout862 and oldcuz have said thanks
#5 truck21 OFFLINE
truck21
  • 512 Thanks
  • 291 posts
Posted September 05, 2016 - 09:21 AM
Yeah definitely the wrong engine cradle. Send me a pm I may be able to help you out with a manual and also the correct cradle if you can't find one locally.
#6 oldcuz OFFLINE
oldcuz
  • 68 Thanks
  • 107 posts
Posted September 05, 2016 - 01:13 PM
Merle013
Yes sir I found one in a little better shape than the last one and for a good price,
I will probably wind up taking the engine off and see if I can figure out that cradle if
its even the right one.
#7 oldcuz OFFLINE
oldcuz
  • 68 Thanks
  • 107 posts
Posted September 05, 2016 - 01:24 PM
Yeah something is way off I am going to address that little issue 1st
thing its don't look long enough front to back to line up the bolts.
#8 oldcuz OFFLINE
oldcuz
  • 68 Thanks
  • 107 posts
Posted September 05, 2016 - 01:34 PM
Enginerod
the rear ears on the cradle like you said looks like they should and would sit
on top of the rear isolators not how its sitting now its bolted to the front now
and to short to reach the rear mounts ?
#9 oldcuz OFFLINE
oldcuz
  • 68 Thanks
  • 107 posts
Posted September 05, 2016 - 01:54 PM
truck21
You may be right on the wrong cradle it might have came with the engine that
was on a different brand tractor I found a manual for 200-210-212-214 but it
did not have a good photo of how the engine mounted or a diagram of the mounts.
I might need a cradle from you parts are hard to find around here I will look
here locally 1st, if you have a different manual let know I'll send you a email
address to send your manual to, thank you for your help
Edited by oldcuz, September 05, 2016 - 10:34 PM.
#10 oldcuz OFFLINE
oldcuz
  • 68 Thanks
  • 107 posts
Posted September 05, 2016 - 10:37 PM
I think I will go ahead and take off the deck so I want be tripping over it and maybe start cleaning and
and rust killing it make sure the bearing are good sharpen the blades put a little paint on it no big
hurry long as I get it done for next year might take that long to get the tractor running, hope not
#11 truck21 OFFLINE
truck21
  • 512 Thanks
  • 291 posts
Posted September 06, 2016 - 11:05 AM
Something doesn't look right as far as the engine goes. Are you sure it's a 10hp?
#12 tater195 OFFLINE
tater195
  • 2,264 Thanks
  • 1,443 posts
Posted September 06, 2016 - 11:12 AM
I stay away from the greenies, but something doesnt look right. What is with the tapered shaft and goofy looking pulley, is that stock?
#13 oldcuz OFFLINE
oldcuz
  • 68 Thanks
  • 107 posts
Posted September 06, 2016 - 12:24 PM
truck21
Kohler K241 10hp
#14 oldcuz OFFLINE
oldcuz
  • 68 Thanks
  • 107 posts
Posted September 06, 2016 - 12:28 PM
tater195
I don't have clue wished I knew, still trying to figure it out ?
#15 truck21 OFFLINE
truck21
  • 512 Thanks
  • 291 posts
Posted September 06, 2016 - 02:40 PM
I'll post a picture of the engine that should be in it when I get a chance.
