What am I doing wrong?
7 replies to this topic
#1 bbuckler OFFLINE
bbuckler
  • 2,346 Thanks
  • 2,128 posts
Posted September 03, 2016 - 07:13 PM
The valves on my SS15 is 0.25 and they need to be at max 0.09. I been up there for a hour and a half using coarse lapping compond and not seeing any results.
#2 ol' stonebreaker ONLINE
ol' stonebreaker
  • 1,501 Thanks
  • 1,074 posts
Posted September 03, 2016 - 08:20 PM
  I'll assume you meant 0.025" and 0.009". If these are new valves make sure they're the right ones. If so then you may have to have someone w/ a valve grinder take some out of the seats 'cause 0.016" is a lot to remove lapping and it might throw off the geometry between the valve and seat.
                               Mike
Edited by ol' stonebreaker, September 03, 2016 - 08:48 PM.
  • boyscout862 and Bill 76 have said thanks
#3 bbuckler OFFLINE
bbuckler
  • 2,346 Thanks
  • 2,128 posts
Posted September 03, 2016 - 08:21 PM
It was a metric feeler gauge
#4 ckjakline OFFLINE
ckjakline
  • 1,120 Thanks
  • 1,114 posts
Posted September 03, 2016 - 08:53 PM
Is your tolerance in metric also? 250 microns = .010"
#5 Bill 76 OFFLINE
Bill 76
  • 1,748 Thanks
  • 1,111 posts
Posted September 04, 2016 - 03:10 AM
unless my math is wrong you have to take off .006 thousandths of an inch--.0063 to be precise
or  .16 millimeter   you will be lapping for days  to remove that.
Take the valve in and have them grind the face down a touch. If they go to far it's much easier to stone down the tip of the stem to get your clearance back.
  • chieffan said thank you
#6 bbuckler OFFLINE
bbuckler
  • 2,346 Thanks
  • 2,128 posts
Posted September 04, 2016 - 08:39 AM
I grab the wrong feeler gauge out of the toolbox
#7 Lmiller3358 ONLINE
Lmiller3358
  • 1,400 Thanks
  • 1,368 posts
Posted September 04, 2016 - 08:47 AM
They were next to the metric pliers, right ?
  • MH81, Bruce Dorsi and Bill 76 have said thanks
#8 EricFromPa ONLINE
EricFromPa
  • 2,671 Thanks
  • 2,538 posts
Posted September 04, 2016 - 10:12 AM
Valve clearance on a Cast Iron Briggs should be in Inches Intake .007 / .009 exhaust .017 / .019
If anything your Intake valve stem might need a little grinding.Mine was to tight after lapping them so I had to take it out and touch it on the grinder.
If the intake valve is to tight like mine was it will cough and sputter and you will see an abnormal amount of seepage from every gasket and small hole in the carburetor.Comes from the valve not closing tight enough and it pressurizes the carb.
  • MH81 and tractorgarden have said thanks
