Allis chalmers 914-s re-power
11 replies to this topic
#1 Taylorv OFFLINE
Taylorv
  • 4 Thanks
  • 9 posts
Posted September 02, 2016 - 01:37 AM
i could use any and all info or help on how to do a swap 23hp Briggs and stratton vanguard into a 914-s or should i get a yanmar 3cyl 18hp diesel to swap instead??? i already have the 23hp, but i can get the yanmar for $350.00 obo. i also have a 16hp briggs and stratton vanguard. what should i do???????
  • chieffan said thank you
#2 boyscout862 ONLINE
  • 12,831 Thanks
  • 9,158 posts
Posted September 02, 2016 - 06:08 AM
Welcome to GTT. You can do whatever you want. I would put the 16hp in it to make sure everything works right. Then I would use it for awhile. I've already done it where I fixed up a tractor and then found that I didn't like it(because I'm too big for it). Check out our Manuals Section for free downloads. Good Luck, Rick
Edited by boyscout862, September 02, 2016 - 08:14 AM.
#3 Trav1s ONLINE
Trav1s
  • 3,293 Thanks
  • 4,351 posts
Posted September 02, 2016 - 07:08 AM
The Yanmar will be more work.  Remember that the driveshaft attaches to the front of the engine and the PTO is on the rear of the engine.  You will also need to figure out the cooling system.  After looking at pics of the machine it looks like more work than me considering a 3 cylinder Yanmar Diesel swap in a John Deere 318.  After looking at the engine next to the tractor, I am going to go with a Vanguard or a Command for the repower.
If you are set on a diesel, I'd suggest a small 2 cylinder option.
Edited by Trav1s, September 02, 2016 - 07:09 AM.
  • boyscout862 and chieffan have said thanks
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted September 02, 2016 - 09:29 AM
:welcometogttalk: :camera:
  • Taylorv said thank you
#5 Taylorv OFFLINE
Taylorv
  • 4 Thanks
  • 9 posts
Posted September 02, 2016 - 12:34 PM
if anyone has a perkins or another diesel, i would be willing to trade my 23hp and or my 16hp. what can i use for a adapter to hook up my drive shaft? any and all idea's
#6 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted September 04, 2016 - 08:06 PM
On my swaps I have stuck with the Kohlers. My 916s both have CH20's in them. I reused the original flywheel mount from the single cyl kohler. I think the adapter you have might work if you have new holes drilled in the correct places.
If I had the chance to run a good solid Yanmar I would have gone tat route.
Edited by victor3ranger, September 04, 2016 - 08:07 PM.
#7 Cvans ONLINE
  • 6,634 Thanks
  • 6,125 posts
Posted September 04, 2016 - 09:11 PM
This is a conversion I did several years ago. You might want to take a look at it and see what is involved and then decide which way to go.
http://gardentractor...sel#entry227862
#8 Taylorv OFFLINE
Taylorv
  • 4 Thanks
  • 9 posts
Posted September 19, 2016 - 12:44 AM
for anyone looking to do a vanguard repower, i found this adapter
http://www.ebay.com/...08AAOSwAuZX3xvD
fyi, don't try calling small engine warehouse, they told me they would not sell me a adapter.
Edited by Taylorv, September 19, 2016 - 12:50 AM.
  • Cvans said thank you
#9 Taylorv OFFLINE
Taylorv
  • 4 Thanks
  • 9 posts
Posted September 27, 2016 - 12:05 AM
well so far so good, every thing went well. i'm just having a fuel issue witch i should have fixed tomorrow. the adapter fit vary well
#10 Taylorv OFFLINE
Taylorv
  • 4 Thanks
  • 9 posts
Posted October 03, 2016 - 12:57 AM
#11 Taylorv OFFLINE
Taylorv
  • 4 Thanks
  • 9 posts
Posted October 03, 2016 - 12:58 AM
#12 Taylorv OFFLINE
Taylorv
  • 4 Thanks
  • 9 posts
Posted October 04, 2016 - 01:29 AM
