I'm Stuck with a Stuck Set Screw!
25 replies to this topic
#16 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted August 31, 2016 - 03:25 PM
I haven't found an easy-out, even Strap-On, that was worth anything
#17 heliosuk OFFLINE
heliosuk
  • 274 Thanks
  • 194 posts
Posted August 31, 2016 - 04:36 PM
Got a large battery and set of booster cables?
Stretch the cables out so the battery is not close to where you are working.
Connect one cable to the hub.
Clamp the other cable to a metal rod of some sort that will fit into the hex hole of the screw. I'm thinking a nail/spike will work.
The idea is to get current to flow from the set screw to the hub. Rust between the two is resistance to current flow = heat right where you want it. If you get a puff of rust it worked.
Garry
Sounds highly dangerous to me with a very big risk of the battery exploding. I wouldn't want to try this. I have though heard that soaking in coca cola frees fixings off believe it or not.
Personally I've had remarkable success with phosphoric acid, not sure why but read it somewhere!
  • LilysDad and flyboy have said thanks
#18 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5122 Thanks
  • 2911 posts
Posted August 31, 2016 - 04:41 PM
:rolling:  :rolling:  :rolling:    Freudian slip??
  • WNYTractorTinkerer and ClassicBolens have said thanks
#19 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1692 Thanks
  • 1148 posts
Posted August 31, 2016 - 05:01 PM
  I would use the small O/A welding tip to heat the area around the screw to almost orange. Do this w/ the pulley in a vice and once heated start working it back and forth w/ the allen wrench. If it will screw in easier than out, then do so. If it hits the other side of the bore, cut it off w/ the torch and just get a new screw. After it's cooled run a tap thru the threads.
                                        Mike
  • Alc and flyboy have said thanks
#20 lrhredjb OFFLINE
lrhredjb
  • 1068 Thanks
  • 779 posts
Posted August 31, 2016 - 05:51 PM
I've been told this works but I have not used this method. Heat the part up and use candle wax in the hole. Keep the heat on so the wax remains melted. It's supposed to run into the rusted area and free it up. What have you got to lose?
#21 flyboy OFFLINE
flyboy
  • 59 Thanks
  • 50 posts
Posted September 01, 2016 - 06:39 AM
I knew I could depend on you all for some great ideas / suggestions!!  Now all I have to do is pick one OR - if it is really bad,  I will try them all!
I am really intrigued by the battery idea GWest posted. Even if it doesn't work it is always fun to blow stuff up - I hope it is not the battery -- (really LONG jumper cables)!
THANK YOU ALL!!!
#22 Alc OFFLINE
  • 9087 Thanks
  • 8326 posts
Posted September 01, 2016 - 08:00 AM
If you had a stick welder and ever had the amps set too low and got the rod stuck I would think it would be the same .
#23 JBRamsey OFFLINE
JBRamsey
  • 1642 Thanks
  • 911 posts
Posted September 01, 2016 - 07:46 PM
Read the ingredients on your Coke can. It includes phosphoric acid.
#24 jabelman OFFLINE
jabelman
  • 2401 Thanks
  • 1668 posts
Posted September 01, 2016 - 07:52 PM
thanks everyone I just bought another panzer 2 days ago and guess my luck when I went to get the 3 grooved Pulley off, stripped set screw because someone tried drilling it out years ago. so my only option I finished drilling it out and have it soaking in pb blaster, hopefully tomorrow it pops off with the puller.
nothing is easy, have to re thread it
Edited by jabelman, September 01, 2016 - 07:53 PM.
#25 flyboy OFFLINE
flyboy
  • 59 Thanks
  • 50 posts
Posted September 02, 2016 - 06:06 AM
I agree.
Once the pulley is off the shaft, the keyways can be examined for wear or distortion.
The setscrews can be removed or new holes drilled & tapped.
Great idea! Unfortunately the pulley is loose and slides, But won't come off the shaft.
#26 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 18306 Thanks
  • 7714 posts
Posted September 03, 2016 - 11:44 AM
Puller time!
