Spray gun extension
11 replies to this topic
#1 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted August 30, 2016 - 08:44 PM
I wanted to spray the frame on my GMC pick-up  and was looking for how my regular  full size  spray gun can be changed to pressure feed. Thought this way I could spray in all directions , maybe ?  Anyway I came across someone who added and extension to his touch-up gun . I looked at mine and it was made the same , what I  did ,,unscrew the gun from the cup and add a vacuum hose with the proper pipe fittings . It worked great !  I could turn the gun in any direction  with one hand and just hold the cup as close as possible to vertical . About a foot  lower and it didn't want to siphon but I was spraying Rustoleum  and maybe if thinned a little more it might not have had any problems .No way could I have gotten around the exhaust and driveshafts  using it upside down with a full size gun or even the touch-up gun with the cup attached  .   Went I painted my Ford tractor there were times I couldn't  get under and behind to paint but this would have gotten those areas and then I could have used the bigger gun on the wide open parts .  The only drawback would be the small cup size , it was a pita climbing out so may times to fill
Edited by Alc, August 31, 2016 - 05:30 AM.
  • DougT, Gtractor, Bruce Dorsi and 16 others have said thanks
#2 HANKG OFFLINE
HANKG
  • 6,306 Thanks
  • 3,420 posts
Posted August 30, 2016 - 09:06 PM
Great innovation AL
#3 shorty ONLINE
shorty
  • 5,475 Thanks
  • 5,258 posts
Posted August 31, 2016 - 04:26 AM
Cool idea Al. Neat way to use what you already have.
#4 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted August 31, 2016 - 05:08 AM
Great idea!
#5 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted August 31, 2016 - 05:33 AM
Thanks guys but this was just something I stumbled on and like most of us we don't paint for a living or like me only once and a while so everything we can find to make a job easier we pass the info on to each other
  • DougT, KennyP, MFDAC and 1 other said thanks
#6 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 8,587 Thanks
  • 2,831 posts
Posted August 31, 2016 - 12:38 PM
Good idea - thanks for sharing.  I would suggest you use a good quality hose and clean it out really well before and after each use - otherwise you could end up with contamination from the hose that could react with the paint - just a thought. You could use the smaller spray head with a quart paint cup so that you did not have to refill it as often but it will be heavier to hold.
#7 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted August 31, 2016 - 05:04 PM
  Thanks, Al !! I have a small gun like your's and have done small tight jobs where the hose would really help.
                                 Mike
#8 MFDAC OFFLINE
MFDAC
  • 3,214 Thanks
  • 1,586 posts
Posted September 08, 2016 - 07:41 PM
Great tip Al! I'm cleaning up the front section of a GMC frame for some paint too. I don't have as many obstacles but I may steal this idea anyway!
DAC
#9 pick-to-stone OFFLINE
pick-to-stone
    Living in the past
  • 366 Thanks
  • 500 posts
Posted September 14, 2016 - 03:05 PM
Wow good idea jest wants me to get my tractor out to my grandfather shop to sandblast it so I can repaint it
#10 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,288 Thanks
  • 9,776 posts
Posted September 20, 2016 - 03:42 PM
Smart! I use that small gun for GT painting. Would a grease gun extension work?
#11 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted September 20, 2016 - 08:14 PM
The ends I used were " pipe swivel " not sure if you could get it seal but heck give it a try !
#12 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted September 21, 2016 - 05:50 AM
Here's a cross section of a pipe swivel , it doesn't use the tapered threads to seal but the cone shaped inside this way you tight the nut without having to turn either attaching pipes . you also need to have a male pipe fitting with a taper to match the cone
  • KennyP and LilysDad have said thanks
