200 Drive belt replacement
5 replies to this topic
#1 adamjd200 OFFLINE
adamjd200
  • 2,084 Thanks
  • 2,201 posts
Posted August 30, 2016 - 07:44 PM
Finally to the point where all I have left to do on my 200 is tie up a few loose ends and change the drive belts, the back one (variable drive to transaxle) is pretty obvious, what I am unsure about is how to change the front belt at the engine, do I have to completely remove the PTO  in order to change it?
#2 lyall ONLINE
lyall
  • 2,170 Thanks
  • 1,573 posts
Posted August 30, 2016 - 08:14 PM
First remove the secondary belt from the variator.
I use a clamp to hold the clutch pedal down.
You need to remove the PTO arm from the end PTO.
Then you should be able the remove the main drive belt.
  • adamjd200 said thank you
#3 adamjd200 OFFLINE
adamjd200
  • 2,084 Thanks
  • 2,201 posts
Posted August 30, 2016 - 09:07 PM
That's what I was thinking, the installation is just the whole thing reversed, correct?
#4 lyall ONLINE
lyall
  • 2,170 Thanks
  • 1,573 posts
Posted August 30, 2016 - 10:22 PM
you got it
#5 pidjones ONLINE
pidjones
  • 58 Thanks
  • 51 posts
Posted August 31, 2016 - 04:42 PM
I use a deep well (don't remember the size) on an extension to put I through the square hole in the frame and over the secondary idler bolt to keep it up out of the way for doing that one.
#6 lyall ONLINE
lyall
  • 2,170 Thanks
  • 1,573 posts
Posted August 31, 2016 - 07:55 PM
some of the earlier 200 series do not have a hole for the secondary drive.  My 75 214 does not have a hole in the frame.  I had to hold it up by hand to remove the belt.
