Another project bites the dust
12 replies to this topic
#1 Orange appeal OFFLINE
Orange appeal
  • 303 Thanks
  • 229 posts
Posted August 30, 2016 - 03:14 AM
Finally got the ole sicklebar hooked up . Just need belt sizes now and I can put it to use. Only cost me about twenty bucks in chain and other stuff from the local hardware store. Pretty excited can't wait to use it.
  • Gtractor, Alc, KennyP and 5 others have said thanks
#2 KennyP ONLINE
  • 37,517 Thanks
  • 45,516 posts
Posted August 30, 2016 - 05:03 AM
Cool! I have used an old broken belt to measure for unknown length belts.
  • boyscout862 and chieffan have said thanks
#3 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted August 30, 2016 - 05:48 AM
That bar looks long and heavy. What kind of counter weights are used on AC units ? Glad you are getting it attached they do ditches way better than standing around with a weed-eater :thumbs:
#4 MH81 OFFLINE
Posted August 30, 2016 - 06:11 AM
That looks nice!, you'll enjoy using it.
Just to check, do you have a couple of wheel weights to put in the left rim? Especially working banks, you'll want the counter weight.
Don't want to read about you in the paper.
  • KennyP, boyscout862 and chieffan have said thanks
#5 Orange appeal OFFLINE
Orange appeal
  • 303 Thanks
  • 229 posts
Posted August 30, 2016 - 06:26 AM
It's just for show for now I doubt I'll use it for a while at least till I have somewhere to play with it at. As for counter weights idk if it has any I'll have to look boy do they link up nice though and that chain was perfect length.
#6 chieffan ONLINE
  • 9,607 Thanks
  • 6,427 posts
Posted August 30, 2016 - 07:15 AM
Looks to me like the bar should be about straight up and down when in transport mode.  Take a lot of side pressure off and lot less sticking out to catch something, like a truck mirror or the door opening.  Definitely need counter weights on that left side.  Fill the left tires with fluid will help.  Nice looking set up.  would like to find one for one of my Bolens or Cub.
  • boyscout862 and Orange appeal have said thanks
#7 Orange appeal OFFLINE
Orange appeal
  • 303 Thanks
  • 229 posts
Posted August 30, 2016 - 07:45 AM
I don't know I looked at it yesterday cause I thought the same thing but there isn't any way to do it the handle bar is up against the hood already does anyone know if you can bring it in tighter ?
#8 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted August 30, 2016 - 09:38 AM
If that setup is like my Haban 401 on my Jake, there should be several positions that lift handle can be moved to. Mine is spring loaded, and requires no tools to move, Id look at that a little closer :)
#9 Talntedmrgreen OFFLINE
  • 3,230 Thanks
  • 2,301 posts
Posted August 30, 2016 - 06:01 PM
Yup, there is a second position to the bar but it is for transport position. The chain is used for transport, and should be drawn in quite a bit further qhen the handle is in the next position.
  • MH81, ACmowerguy and Orange appeal have said thanks
#10 ACmowerguy OFFLINE
ACmowerguy
  • 386 Thanks
  • 355 posts
Posted September 03, 2016 - 09:25 PM
I found that when I tried to mow across the top of my bank, I could not steer uphill due to the side draft of the sickle. I had to tow the tractor off the hill with the 7016H.  Front wheel weights would be helpful.
Edited by ACmowerguy, September 03, 2016 - 09:29 PM.
#11 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted September 04, 2016 - 11:41 AM
I have wanted a sickle for a while now. Just can't find them around here.
  • KennyP and wbakunis have said thanks
#12 KennyP ONLINE
  • 37,517 Thanks
  • 45,516 posts
Posted September 04, 2016 - 03:46 PM
I'd have fun with one! Kinda like hen's teeth around here!
#13 SimplyRad OFFLINE
SimplyRad
  • 1,020 Thanks
  • 788 posts
Posted September 05, 2016 - 11:53 AM
I thought about buying a new one back around 1972 for my Simplicity but ended up hiring someone to mow the 10 acres instead. The cost was cheaper to hire.
