question for the Gravely/Onan masters
7 replies to this topic
#1 norwee OFFLINE
norwee
  • 17 Thanks
  • 40 posts
Posted August 28, 2016 - 02:19 PM
Long story but the quick version is:
mowed with the gravely, forgot to shut off fuel valve,overflowed into carb then into portside cylinder.
pulled heads. clean up cylinders(no abrasive).replaced gaskets. torque heads. change oil and filter charge battery. start engine. drive 15 feet forward in low /low. turn off key, engine shuts off immediately. wiill not restart. pull plugs. crank by hand with socket on fan bolt/nut. hard to turn. what have I done?
2 weeks ago this was a mowing machine now its dead in the shop. tried some Kroil in cylinders to act as lube. stiil no go. hope I haven't toasted the engine.
thought? suggestions?
#2 KennyP ONLINE
  • 40,126 Thanks
  • 46,764 posts
Posted August 28, 2016 - 02:54 PM
Dang! That doesn't sound good.
  • norwee said thank you
#3 norwee OFFLINE
norwee
  • 17 Thanks
  • 40 posts
Posted August 28, 2016 - 03:20 PM
on another note your 450 is running and mowing. i'm going to put the 30 inch brush hog on the front and cut down some hillside tall grass.
#4 KennyP ONLINE
  • 40,126 Thanks
  • 46,764 posts
Posted August 28, 2016 - 03:33 PM
Glad it is working good for you. The other one sounds like it may take $ to fix it!
#5 norwee OFFLINE
norwee
  • 17 Thanks
  • 40 posts
Posted August 28, 2016 - 07:19 PM
i posted on MTF also and the Onan master Richard-tx has replied. hope fully he has another idea without large $ involved. I may be in the market for an ONan or a kohler
#6 MH81 OFFLINE
Posted August 28, 2016 - 10:05 PM
Can you do a compression test?
#7 norwee OFFLINE
norwee
  • 17 Thanks
  • 40 posts
Posted August 30, 2016 - 05:11 AM
I tried last night using a breaker bar to turn the engine. can't spin it fast enough to reall get a comp reading. by hand both sides showed 15. but like I said it fired up and ran fine. going to pull the heads and try some stp lube in the cylinders and more hand cranking. no gas in the oil i'm going to swap out starters too, if I can figure out how to get the starter out. i'll be out of country for two weeks starting tomorrow.
#8 norwee OFFLINE
norwee
  • 17 Thanks
  • 40 posts
Posted October 16, 2016 - 08:03 AM
I took this engine to the local vo-tech small engine class. We pulled off the flywheel and the sump. discovered main bearing is bad. needs a little more tear down and then off to parts supplier for bearings.
