1969 john deere 112 secondary belt idler pully
2 replies to this topic
#1 tinmanruss OFFLINE
tinmanruss
  • 2 posts
Posted August 28, 2016 - 12:51 PM
I was cutting grass and the machine stopped moving I took it apart and the spring was missing from the
secondary idler pulley, I got a new spring and hooked it to the pulley but where does it hook to the frame?
I have looked and I can't seem to find the spot. Can you help me ?
#2 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted August 28, 2016 - 02:01 PM
the secondary spring connect to the frame.  There is a little hole in the frame for the spring to connect to.
In the picture it is close to the end of the clutch shaft.
The picture is for a 112 serial number 250,000- and up. but it should also be for the lower serial numbers.
hope this helps
  • tinmanruss said thank you
#3 tinmanruss OFFLINE
tinmanruss
  • 2 posts
Posted September 05, 2016 - 06:53 AM
I found the spot I put the new spring in and it works I think I need a new primary belt also. thanks for the help Iyall.
