Haul home a Deere 318 and a half 212
7 replies to this topic
#1 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,605 Thanks
  • 1,306 posts
Posted August 27, 2016 - 11:16 PM
I'm a sucker to drag in a old (vintage) GT any time I can. I sure didn't need anything else to work on right now but I have any addiction  :D . So I drug this 318 out of the weeds tonight. It has a rebuilt Onan but the dip stick tube started leaking and got bad so he parked it last spring. The 212 has a bad transaxle but a good K301 engine and other good parts.The 318 is a 1988 by the serial number and appears to be in pretty good overall condition,peeling paint not withstanding. Here's a few pictures.
  • Alc, KennyP, CRFarnsworth and 1 other said thanks
#2 Mtypython OFFLINE
Mtypython
  • 338 Thanks
  • 338 posts
Posted August 28, 2016 - 06:56 AM
Not a bad haul
  • rustyoldjunk said thank you
#3 Trav1s ONLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted August 28, 2016 - 07:24 AM
That 318 likely has peeling powder coat on it.  Deere had a real problems with powder coating on machines of that vintage.  My '88 318 has been repainted and I am sure it is for that reason.  Nice haul!
That 212 has a fair amount of good parts on it.  Looks like a 39 deck.
Edited by Trav1s, August 28, 2016 - 07:25 AM.
  • rustyoldjunk and Alc have said thanks
#4 chieffan ONLINE
  • 9,573 Thanks
  • 6,411 posts
Posted August 28, 2016 - 07:44 AM
Good haul even though I am not a fan of green machines.  Engines alone are worth haul home.
#5 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,605 Thanks
  • 1,306 posts
Posted August 28, 2016 - 11:57 AM
I put the booster on the battery and a little gas in the carb. The Onan fired up and sounded good. It is completely packed with mouse nesting though so a complete tear down of the engine tins and cleaning is in order before I can run it. All air cooled engines need to be kept clean but Onans especially like to run hot easily.
#6 CRFarnsworth ONLINE
CRFarnsworth
  • 4,576 Thanks
  • 2,109 posts
Posted August 28, 2016 - 12:05 PM
I can't beleive you put that much GREEN in your shop!!      :(      Rick
#7 rustyoldjunk OFFLINE
rustyoldjunk
  • 2,605 Thanks
  • 1,306 posts
Posted August 28, 2016 - 02:08 PM
Just basically saving the 318 CR. I don't have much desire to mess with it right now. It will make somebody a good tractor though. I will probably have it listed for sale in a week or less. I can't afford Deere parts and attachments. I also ain't crazy about the fact that they copy right most of their literature so its tough to get good manual info without buying them.
Edited by rustyoldjunk, August 28, 2016 - 02:09 PM.
#8 KEYBEAR OFFLINE
KEYBEAR
  • 7 Thanks
  • 23 posts
Posted September 09, 2016 - 07:23 AM
Back in the day i bought a new John Deere 318 It was in the winter so it set untill spring .
That spring I started it the first time and moved it outside and let it run ( warmup ).
Next time I looked it was on fire the battery cable was installed wrong and shorted out ?
The dealer sent a new one out next day with the battery cable routed correctly .
