Wisconsin Engine Questions
aks bknd with 5.5-1 reduction
8 replies to this topic
#1 Paulgo OFFLINE
Paulgo
  • 691 Thanks
  • 462 posts
Posted August 27, 2016 - 12:53 PM
I picked up a BKND with 5 1/2 to 1 reduction gearbox a while back. Was like new on the inside, but had damage to the exterior-- carb was broken, air filter and gas tank gone, etc. I have no use for the engine, but figured it was worth rescuing and worry about finding a buyer afterwards.
Found a replacement carb on epay, but still needed a tank and filter. Got lucky the other day and came across an intact AKS sitting on a dirt floor in a barn. Bottom of blower housing is rotted away, but crank still turns over. Appears to have a valve stuck open and the spark plug threads are stripped in the head. Magneto clicks, but I am not sure if it is working. Has a very nice carb, oil bath air filter, and fuel tank.
The filter hangs from an elbow and is held on with screws. Elbow is too small to fit on BKND carb. Can be hung from the BKND elbow. All I have to do is drill 3 holes in elbow to hold filter in place. Old filter would have been held with wire over top.
The filter housing is stuffed full of steel wool. Looks original. In good shape on top, but rusty on bottom. Do I pull that out and clean it, replace it, or what?
The gas tank is nice and solid. I can see a little rust inside on the bottom. Dumped some witches brew of atf/acetone inside to help clean it up. Will slosh some gas in a day or two to flush it. Will that be enough, or should I do more?
Tank has a sediment bowl. I guess those are almost, but not quite, an inline filter? What is the threaded rod sticking out of the right side? Would that act as a shut off or is it just a plug?
Open to any and all advice.
Paul
  • Bolens 1000 and boyscout862 have said thanks
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted August 27, 2016 - 01:11 PM
Settling bowl is the filter. Yes, that is a shut off
  • Paulgo said thank you
#3 michael.kitko OFFLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted August 27, 2016 - 01:13 PM
Hey Paul, I just almost finished rebuilding my TJD and if I may give you a name, Rock Creek Consulting. He advertises on EBay, but his prices are cheaper if you just call direct for what you need. It is a legitimate business. I ordered a wire set first and tested it that way.
Hours M-Th 9am to 6pm ESTFri. Sat. by Chance or Appt.
814-766-3675
Waterside, Pa
I DO NOT ACCEPT PAYPAL.
MONEY ORDERS OR PHONE IN CREDIT CARDS (VISA,MC)
Mike "Squirrelly" Kitko
  • boyscout862 and Paulgo have said thanks
#4 boyscout862 ONLINE
  • 12,542 Thanks
  • 9,041 posts
Posted August 27, 2016 - 09:28 PM
814-766-3675
Waterside, Pa
Isn't that a 2 cylinder engine? What are you using it on? Thanks for the info. Good Luck, Rick
Edited by boyscout862, August 27, 2016 - 09:29 PM.
#5 michael.kitko OFFLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted August 27, 2016 - 09:36 PM
814-766-3675
Waterside, Pa
I am kinda in the middle of building an articulated 140. I found one with a pretty bad middle and the engine mount was cut all up. So I chopped it up and I am working on that build right now. The motor is going to be that TJD I have. I figured the TJDs sound like an old two cylinder and I could have imagined JD going with that as an air cooled motor in a garden tractor that will kinda look like a 7520. Sorry to hijack the thread.
#6 Paulgo OFFLINE
Paulgo
  • 691 Thanks
  • 462 posts
Posted August 27, 2016 - 10:08 PM
Any advice on servicing that oil bath air filter?
#7 Bolens 1000 OFFLINE
  • 14,903 Thanks
  • 18,103 posts
Posted August 28, 2016 - 07:33 AM
Nice engine
The sediment bowl has a very fine screen and is pretty much all you need for a filter on these engines, looks like someone added something to the valve though as they were originally just a t-handle
The air filter can be soaked on some mineral spirits rinsed out and used again, some of the real early oil filters have horse hair in them!
#8 Paulgo OFFLINE
Paulgo
  • 691 Thanks
  • 462 posts
Posted August 28, 2016 - 09:03 AM
Do I pull that steel wool out of there for cleaning or is that liable to screw it up?
#9 Bolens 1000 OFFLINE
  • 14,903 Thanks
  • 18,103 posts
Posted August 28, 2016 - 09:24 AM
You can pull it out that stuff is pretty well bound together
