Old Bolens Walk Behind
#1
OFFLINE
Posted August 25, 2016 - 06:15 PM
- Bolens 1000, LPBolens, Alc and 7 others have said thanks
#2
ONLINE
Posted August 25, 2016 - 06:45 PM
I have no idea on values but I do know its a great find, the plow attachment is also a good find as these are usually found without the attachments and those are harder to find than the machines
There are a couple walkbehind guys here that can give you some more info
- Alc and Lauber1 have said thanks
#3
OFFLINE
Posted August 25, 2016 - 07:44 PM
The interesting thing to me is has Briggs model R2 on it This model the DQ should have a model Q on it. The R and Q are very similar but they have different carburetors on them the one on this tractor has correct R carb on it. As far as I know no Bolens walk behind came factory with a R engine on it. On the other hand this engine sure looks original and has Bolens name on tank, so who knows what may have happened. Very nice example of early Bolens tractor maybe Canada only ?
- Gtractor, Alc, Bruce Dorsi and 1 other said thanks
#4
OFFLINE
Posted August 25, 2016 - 07:46 PM
- Bolens 1000, LPBolens, Alc and 3 others have said thanks
#5
OFFLINE
Posted August 25, 2016 - 07:48 PM
mine has a r engine on it as well The late model DQ's came with R engines This makes the third one I have seen with an RThe interesting thing to me is has Briggs model R2 on it This model the DQ should have a model Q on it. The R and Q are very similar but they have different carburetors on them the one on this tractor has correct R carb on it. As far as I know no Bolens walk behind came factory with a R engine on it. On the other hand this engine sure looks original and has Bolens name on tank, so who knows what may have happened. Very nice example of early Bolens tractor maybe Canada only ?
- Bolens 1000, Gtractor, LPBolens and 4 others have said thanks
#6
OFFLINE
Posted August 25, 2016 - 07:52 PM
#7
ONLINE
Posted August 26, 2016 - 01:20 AM
I wouldn't pay more than $300 for one in that condition
Good gravy I was thinking maybe $100 if the carb didn't look to bad.Never seen one quite that big around here tough.
The drive chains look to be pretty solid.Going to be a challenge to load up without a couple nice wide planks and a winch or a tractor with a loader lol.
- Gtractor said thank you
#8
ONLINE
Posted August 26, 2016 - 06:42 AM
That R2 B&S engine (serial # 1824) was built in October, 1930.
- Bolens 1000 said thank you
#9
ONLINE
Posted August 26, 2016 - 08:03 AM
A Bolens machine was made by Gilson?
#10
OFFLINE
Posted August 26, 2016 - 11:04 AM
Nice little living room conversation piece once it's restored
#11
OFFLINE
Posted August 26, 2016 - 11:12 AM
I'd buy it as is for parts $100.00 and go from there once you get into it. Everyone puts a different value on this stuff. If it were restored or a good running original it would be easier to put a price on it (I think)
#12
OFFLINE
Posted August 26, 2016 - 09:20 PM
. You have to think about the value of the engine that's where the money is at tractor by itself had very little valueGood gravy I was thinking maybe $100 if the carb didn't look to bad.Never seen one quite that big around here tough.
#13
OFFLINE
Posted August 27, 2016 - 05:23 AM
Thanks for your input, everyone. I appreciate it. I'll see what I can do, see if I can talk him into selling it and for a reasonable amount. It sounds like I wasn't too far off in my own feelings as to its value. I will keep you posted, but I would suspect that nothing will happen any time soon. We'll see though. Mostly I just don't want to see it waste away any more than it already is. Thanks again.
- Alc said thank you
#14
OFFLINE
Posted August 27, 2016 - 02:38 PM
Not built by Gilson.
You need to read up on bolens history.
#15
ONLINE
Posted August 27, 2016 - 03:19 PM
Sorry, I was just reading the tag.
