Briggs Model 5s carb Issue
13 replies to this topic
#1 GTpicker01 ONLINE
GTpicker01
    GT Addict
  • 648 Thanks
  • 555 posts
Posted August 24, 2016 - 02:12 PM
I have an Eclipse reel mower with a Briggs model 5s engine that I like to use and take to shows. Now, at some point I would like to restore this little thing, but the carb keeps me from doing that and here is why. It runs great when it runs, but if I let it sit longer than 2 weeks I have to take the carb off and spray carb cleaner into the end of the the pickup tube and free up the little ball in there. I'll be honest, I've been doing this for 2 years now with the thing and I am getting tired of it. I treat all my gas with ethanol stabilizer and marvel mystery oil. is there something I can do to really clean up that pickup tube? Maybe soak it in something? Is it possible to put in a new pickup tube? I know the tube is sealed in there with a kind of putty and I haven't tried to remove it. Should I get a new carb? Any advice would be appreciated!
Mike
#2 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,173 Thanks
  • 5,770 posts
Posted August 24, 2016 - 02:16 PM
I'd find a new carb if possible
  • GTpicker01 said thank you
#3 GTpicker01 ONLINE
GTpicker01
    GT Addict
  • 648 Thanks
  • 555 posts
Posted August 24, 2016 - 02:43 PM
I was afraid I was going to hear that lol
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,173 Thanks
  • 5,770 posts
Posted August 24, 2016 - 02:45 PM
Sometimes there's just nothing else you can do
  • EricFromPa said thank you
#5 EricFromPa ONLINE
EricFromPa
  • 2,778 Thanks
  • 2,592 posts
Posted August 24, 2016 - 02:55 PM
I hear that lol.Spent days working on a Briggs model N coil.Needed rewound.In the end I just bought another $25 coil for it.My rewire sorta worked.Had spark but very weak.I must of nicked or cracked the coating on the wire when I was rewinding it.
My 1st rewind didn't go to good lol.Lesson learned don't be a cheap arse and try to save $15. :rolling:
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,173 Thanks
  • 5,770 posts
Posted August 24, 2016 - 02:56 PM
Being "frugal" can really cost you more overall.Sometimes
  • Bolens 1000 and GTpicker01 have said thanks
#7 GTpicker01 ONLINE
GTpicker01
    GT Addict
  • 648 Thanks
  • 555 posts
Posted August 24, 2016 - 03:00 PM
Guess I should now put out a wanted ad.
#8 jabelman OFFLINE
jabelman
  • 1,844 Thanks
  • 1,326 posts
Posted August 24, 2016 - 03:17 PM
I would first run some seafoam through it. I had very good results with that product.
also when I rebuild or need to really clean one I soak it with Berryman carb cleaner, (it comes in a gallon)
#9 chieffan ONLINE
  • 7,280 Thanks
  • 5,147 posts
Posted August 24, 2016 - 03:58 PM
Have you tried running the engine dry before you shut it off?  Or if you are doing this already, use Sta-bail in the fuel and leave the carb full.  Just a suggestion.  I always leave the carb full on all my engines but make sure I have Sta-bail in the fuel as well.
#10 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,666 Thanks
  • 2,339 posts
Posted August 24, 2016 - 04:44 PM
The fuel pick-up tube was/is replaceable.
The original number was B&S # 293700, but I don't know if that number has been superseded.
The intake gaskets (it takes 2) were # 27355, and the carb-to-tank gasket was # 27404.
The gaskets are available through the aftermarket, but I don't know about the fuel pipe.
Check with our sponsors to see what they can offer.
#11 Bolens 1000 ONLINE
  • 13,620 Thanks
  • 17,565 posts
Posted August 24, 2016 - 07:26 PM
Have you replaced the fuel pipe?
I stock the parts for these if needed , including the pipe
http://bolenspartsan...fuel-pipe-5-5s/
#12 GTpicker01 ONLINE
GTpicker01
    GT Addict
  • 648 Thanks
  • 555 posts
Posted August 24, 2016 - 08:39 PM
Nice! I think that would fix my problem. What about the Grey putty that holds the tube in? Will i need to replace that as well?
Edited by GTpicker01, August 24, 2016 - 08:39 PM.
#13 Bolens 1000 ONLINE
  • 13,620 Thanks
  • 17,565 posts
Posted August 24, 2016 - 08:57 PM
That I'm not sure of its been a while since I had one apart, I think they get glued in place or some just get pressed in from what I remember, this one does come with an instruction sheet
#14 GTpicker01 ONLINE
GTpicker01
    GT Addict
  • 648 Thanks
  • 555 posts
Posted August 25, 2016 - 08:34 AM
Well regardless i ordered one from you. I have some gray tank putty if I need to reset the new one in where the old one is. I hope this works as I would really like to restore the old girl.
  • Bolens 1000 said thank you
