Should I buy?
4 replies to this topic
#1 glgrumpy OFFLINE
  • 8,815 Thanks
  • 8,014 posts
Posted August 24, 2016 - 11:00 AM
At show, starts and drives. Briggs twin, runs ruff at idle he says.
  • toppop52 said thank you
#2 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,260 Thanks
  • 6,070 posts
Posted August 24, 2016 - 11:04 AM
Ruff like a dog?    :rolling:
The price is the deciding factor with that...
Oh wait-  You are getting out of the hobby ain't ya?>
#3 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,796 Thanks
  • 5,094 posts
Posted August 24, 2016 - 11:47 AM
NO!   Buy the 861 diesel behind it!  :worshippy1:
I grew up on 861's.  3 diesels and 1 gasser - we didn't change implements too often.  :smilewink:
  • Bill 76 said thank you
#4 toppop52 OFFLINE
toppop52
  • 5,538 Thanks
  • 4,901 posts
Posted August 24, 2016 - 02:11 PM
You don't own it, therefore you need it.
  • WHdbJD and WNYTractorTinkerer have said thanks
#5 EricFromPa ONLINE
EricFromPa
  • 4,174 Thanks
  • 3,352 posts
Posted August 24, 2016 - 03:15 PM
Meh just a lawn mower.Does have a fairly heavy Hydro unit in it though.Steering gears are weak in those.Well more the plastic Steering bushing on the bottom of the column.Causes the gears to slip,strip and break teeth.
https://www.partstre...ector-assembly/
If it's cheap I'de get it and throw a $20 rebuild kit in the carb and fuel pump.The one I had here the deck kept engaging on it's own till I welded up the slots and the tab on the leaver.
Hate the mowers with this style mower engagement.They always wear out.Part to fix it is $16 and 5 minutes of welding and grinding on the lift leaver so it's not bad to fix if it needs it.
https://www.partstre...rts/14231-0637/
